2005 rx8 smoking
Old Nov 18, 2011 | 01:19 PM
joetech's Avatar
2005 rx8 smoking
I am looking at buying an 05 rx8 but it smokes at idle any suggestions or am I looking at an engine teardown and reseal? I never worked on a rotary before.
Old Nov 18, 2011 | 01:23 PM
RIWWP's Avatar
With basically no information to go on we can't really help you.
We can toss out all sorts of theories and suggestions, but there are ways that a rotary can smoke at idle that are acceptable, and ones that aren't. Your post also doesn't indicate volume, length of how long it lasts, color of smoke, any possible modifications that might account for it, or the age/mileage of the car.
It could be anything from a coolant seal damaged/missing, oil seal damaged/missing, to ignition failure to no catalytic converter, etc...
Old Nov 18, 2011 | 01:31 PM
joetech's Avatar
It has 101400 on it the only mod I saw was a greddy cat back it appears that the cat is in place. The smoke has a bluish oil burning look to it. It seems that the smoke is light. I didn't get to see if it continues when it is hot. I am looking for possibilities that can cause it. If the potential is a few easy to swap seals that won't be a deal breaker. Thanks in advance for any help.
Old Nov 18, 2011 | 05:28 PM
DeViLbOi's Avatar
The devil made me do it
What was the ambient temp when you saw the smoke? Might just be normal
Old Nov 18, 2011 | 05:55 PM
xexok's Avatar
White smoke is coolant, blue smoke is oil. My car smokes at idle a bit and after getting on it hard, but I have no cat. You should be able to 100% tell if the cat is on there or not by looking because a midpipe and cat will look very different.
I don't think there are really any "easy seals" to replace on this engine that would cause the smoking you're talking about.
Old Nov 18, 2011 | 06:00 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
We are flying blind..........everyone hold on tight!
Old Nov 18, 2011 | 07:03 PM
DeViLbOi's Avatar
midpipes and cats will look very different if the person didn't take a screwdriver to their cat. Smoke in an RX8 goes from being SOP to overfilled oil to full engine rebuild. You're going to need a lot more info to get anywhere on where it came from. Best bet...find a nice member from your local rx8club chapter and have them go with ya. They can at least tell you if it is normal or not and help you look at the common sources of "smoke".
Old Nov 18, 2011 | 10:13 PM
wcs's Avatar
wcs
no agenda
You need a new zero point energy module
and
+1 post
Old Nov 19, 2011 | 09:31 AM
kevinande's Avatar
Day Walker
and
+1 post
The Apex seals will never hold up under vacuum energy.
Old Nov 19, 2011 | 09:38 AM
DeViLbOi's Avatar
They will if you install a flux capacitor and dump the warp core
Quato_jr
Aug 4, 2015 09:22 AM
MauiMazda2
Aug 3, 2015 02:47 PM
marc2820
Jul 26, 2015 10:47 PM
RX7.9
Jul 20, 2015 12:01 PM
netrovers
Jul 20, 2015 03:32 AM
