This makes me sad
Old Nov 8, 2011 | 02:22 PM
jasonrxeight's Avatar
This makes me sad
I searched "RX8 Belt" to look up the engine belt and this was the FIRST link.
IDK how much this website paid Google but it was sad to read.
http://www.discountautoparts.com/aut...ming-Belt.html
MAZDA RX8 Timing Belt
Description
The MAZDA RX8 timing belt is a flexible rubber belt with molded teeth that grip notches in the camshaft and crankshaft sprockets.
Purpose
The timing belt synchronizes the engine crankshaft with the camshaft, thus the name timing belt.
Maintenance Tips/Suggestions
MAZDA RX8 timing belts are a critical part of engine maintenance program and must be replaced at specified intervals determined by the belt manufacturer or original equipment vehicle manufacturer. Failure to do so may result in catastrophic engine failure. It is best practice when replacing a timing belt that you replace all rotating components that contain a bearing, this would include idler and tension pulleys. On some vehicles the timing belt also drives the water pump. Timing belts are sold separately and as kits that contain idler pulleys, tension pulleys and belt tensioners.
Failure symptoms
Noises coming from under the timing belt cover maybe caused buy worn bearing in the idler and tension pulleys. Timing belts that fail completely will prevent the engine from starting. Timing belts that jump time or are out of phase will cause poor engine performance.
WARNING
Timing belts that fail may cause serious engine damage.
AKA
Timing belt, Sync belt
Location
MAZDA RX8 timing belt is located under timing belt cover. This cover is at the front of the engine and is behind the accessory drive belts that drive the power steering pump, alternator and a/c compressor.
Disclaimer
Depending on the year and options your MAZDA RX8 has, the above information may not apply. Consult with a professional automotive technician or manufacturer for specifics on your MAZDA RX8
Old Nov 8, 2011 | 02:29 PM
lta_ds_fs7's Avatar
Wow..........Idk what to say to that...
Old Nov 8, 2011 | 02:31 PM
maskedferret's Avatar
Oooh, shiny!
Sold! I want one!
Old Nov 8, 2011 | 02:32 PM
lta_ds_fs7's Avatar
I really hope somebody wrote this as a joke...lol
Old Nov 8, 2011 | 02:33 PM
dlum125's Avatar
very funny indeed, but why in the multimedia section??
Old Nov 8, 2011 | 02:39 PM
CRO8TIA's Avatar
This good to know, I dont suppose it also list's a longer duration inlet and exhaust cam too.
Old Nov 8, 2011 | 02:44 PM
Oooh, shiny!
I'm sure this page is just something like a template design where "MAZDA" and "RX8" are [MAKE] and [MODEL]. The website probably crosses all possible combinations between the respective makes and models and spits out the same content, just filling in the blanks; hence the disclaimer.
Examples :
Top search result is mildly amusing nonetheless.
Old Nov 8, 2011 | 03:11 PM
Rootski's Avatar
DGAF
I bought two!
Old Nov 8, 2011 | 03:19 PM
cornholio135's Avatar
SARX
that reminds me my vtac is slow I need to adjust my valves...
Old Nov 8, 2011 | 08:19 PM
Wingznut's Avatar
Go Red Wings!
Will a new timing belt help my power and gas mileage?
Old Nov 8, 2011 | 08:27 PM
J0WUD's Avatar
Old Nov 10, 2011 | 10:37 AM
Grimm0ne's Avatar
Wait What?
1.1gigawatts....
RevMeHarder
Jun 1, 2026 02:30 PM
LB2739
Jul 9, 2019 02:25 AM
Mane
Nov 20, 2015 12:16 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
