Auto tranny upgrade?
Old Nov 6, 2011 | 04:17 AM
von's Avatar
von
I searched transmission and transmission upgrade.
Got three related results for 6 speed units, but not an Automatic.
Please let me know how I can upgrade the automatic tranny to handle 9k rpms or the extra torque say 300rwp+ and maybe stall dumps or whatever you call them, without worrying about a tow home.
Currently, the auto hits 7k and quits, but in the future if replaced with the 6 port Auto, I may lift that limit. Not sure how that works but heard that the Autos couldn't handle the extra 2k rpm.
Old Nov 6, 2011 | 10:23 AM
you searched a generic word is why, there is plenty of info on this subject not to mention and automatic forum area which not only makes this a pointless repost that clogs up the search engine results but also the wrong forum area, all the kids are laughing at you ... again
Old Nov 6, 2011 | 10:34 PM
Giustino's Avatar
Tranny upgrade!
Old Nov 6, 2011 | 10:45 PM
Giustino's Avatar
try http://www.levelten.com/
Old Nov 7, 2011 | 02:43 PM
von's Avatar
von
Originally Posted by Giustino
Thanks Man, checking it out now.
Old Nov 9, 2011 | 11:04 AM
Ravioli's Avatar
404 pistons not found
Why would you try and replicate what a manual can do and in turn, potentially damage your car? Why not just go get a manual?
A level ten torque converter would do the job. But do realize that it is not just the TC that you would need. You'd still need the cobb accessPort in order to bump the redline up to 9k. And then you'd need better tranny oil (preferably redline) and a transmission cooler in order to handle the higher temperatures.
If you want to see if there are any updates for your car, check the Mazda TSB's. (Technical service bulletin). You can potentially get a new TC..
Old Nov 9, 2011 | 12:29 PM
shadycrew31's Avatar
WENTGERMAN
Getting a 6port/6speed to hit 300whp is a feat all on its own.
I recommend trading the car in for an EVO or an STI if you want a fun car with HP.
Old Nov 10, 2011 | 03:20 AM
von's Avatar
von
Because I want an automatic.
Thanks for taking the time to respond
Old Nov 10, 2011 | 03:35 AM
von's Avatar
von
How hard can it be? I have the turblown unit that made 425rwp on their rx8. Two automatics Phill's 8 and 09Factor have 250rwp and 280rwp cars with fuel injectors being the only limiting factor that I can tell from the posts. Hardly a feat but if you think something will keep me from getting past 300rwp let me know and I'll give Turblown a heads up.
Old Nov 10, 2011 | 03:41 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Uhh huh.
Old Nov 10, 2011 | 03:48 AM
von's Avatar
von
Originally Posted by ZumnRx8
Uhh huh.
What does that mean?
Old Nov 10, 2011 | 04:25 AM
bse50's Avatar
#50
Do you realize that turblown's 425hp dyno plot was achieved with 6 port engine?
You will have much more fun just by learning how to drive stick and trade your car for a manual than spending at least 12k$ to make a 4 port reach that goal.
Old Nov 10, 2011 | 06:07 AM
von's Avatar
von
I know it's a 6 port and your point being a 4 port can't flow half that amount with the same turbo? Do you have 4 port flow chart data to back something like this up? I'm not saying this is incorrect, just can't say it is either
Old Nov 10, 2011 | 06:13 AM
bse50's Avatar
#50
It can't flow the same, true. I would also focus on port timing since it is completely different. Some internal parts differ as well.
If your goal is 300 reliable rwhp and you don't have a handicap that prevents you from shifting then my advice is to go 6 port. It will be cheaper and a bit less stressing for the engine.
I'm not bashing any automatric rx8, it's just a fact that reaching that goal on a 4port and a 6port requires a completely different budget
Old Nov 10, 2011 | 07:43 AM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
I will reach 300hp with my 4 port AT. Presently I believe that the injector issue has been solved. I applaud any AT owner with the fortitude to make his AT what he wants it to be. God knows it is difficult because of all the nay sayers, and MT fanboys
As far as cost (budget) well that is a personal matter. I started out figuring that my end cost to achieve 300hp would be significant, mainly because at that time I was pushing the technology of the day. Now I believe that someone can make his dream for significantly less.
Charles (Ray) & Erick with BHR say that they will not allow me to make 300hp because then I will be satisfied and become complacent. They may be right.
Old Nov 10, 2011 | 08:00 AM
bse50's Avatar
#50
You're right but it's also true that when you bought the car the AT was a 4port-4gears.
Nowadays it would be weird to push the limits on a 4 port when there are 6 gears, 6port automatics. Having more gears helps, that's a fact!
This doesn't make me a nay sayer, it surely can be done. Is it worth it? in my opinion nope!
Old Nov 10, 2011 | 08:56 AM
von's Avatar
von
So you were never insisting it can't be done, but that it would cost more? Got it
Anyways, it was suggested that the trans upgraded is not a requirement at the moment but I may need to upgrade at some point.
Old Nov 10, 2011 | 09:01 AM
bse50's Avatar
#50
You got me. I was saying that it could cost more and perform worse than a 6 gear counterpart.
Old Nov 10, 2011 | 09:11 AM
von's Avatar
von
That's ok if it performs worse, just looking to have some cheap thrills for this coming vacation
I was actually perfectly happy with the stock auto. I was surprised that I matched my friends 5 spd 95 Miata 50-undisclosed speed. Can't really claim racing when you excelerate that slow, but there ya go.
Old Nov 10, 2011 | 09:17 AM
WENTGERMAN
I'm saying it cant be done.
Consistent 300+whp is unattainable in a 4 port. I'm talking about pull after pull daily driven street rx8 4 port 4 speed.
You might hit it once one a lucky random day when its cold out and on a fresh engine build. But I guarantee you will be at 250-280 max any given day.
Go try and prove me wrong, I have no evidence. Spend 5 times the value of the car and try and get there.
Godspeed good sir.
Old Nov 10, 2011 | 09:20 AM
von's Avatar
von
Godspeed good sir.
Ok thanks, so what would you suggest to go from consistent 280 to consistent 300rwp that will take 5 times the value of the vehicle?
That is just a 20rwp difference for aprx ~50 grand.
Would you suggest water/meth injection for like a few hundred bucks? That would certainly get me there consistently given what you guarantee in my current setup.
Old Nov 10, 2011 | 09:23 AM
WENTGERMAN
Originally Posted by von
Ok thanks, so what would you suggest to go from consistent 280 to consistent 300rwp that will take 5 times the value of the vehicle? That is just a 20rwp difference for aprx ~50 grand. Would you suggest water/meth injection for like a few hundred bucks? That would certainly get me there consistently given what you guarantee in my current setup.
Your best best is to follow this thread and see what he comes up with.
If anyone has a chance to pull this off its him.
https://www.rx8club.com/series-i-specific-performance-mods-97/jases-hybrid-4-port-auto-6-port-parts-224822/
Old Nov 10, 2011 | 09:29 AM
WENTGERMAN
Also I was assuming your cars value was 5 or 6 k
Old Nov 10, 2011 | 09:33 AM
Phil's 8's Avatar
Well I will not dispute that the 6 port ATs are superior to the 4port ATs (have yet to find one that is as fast as mine) but when you make the decision to purchase a 4port that is what you own and will have to work with. To me it is certainly less expensive than converting a 4port to a 6port and a lot cleaner to just raise the hp. I still have the original tranny even with all the hell I have put it though, with no modifications. Yes it refuses to shift above 8500rpm but can handle 9000 + in any gear.
Not to start a **** storm but on any given weekend in Vegas, some of the MT owners are replacing clutches, replacing trannys, and fixing little things that seem to be a problem on some (if not all) MT 8s. Several have been changed in my garage.
Yes if anyone comes up with a real kit for the 8 tranny (like with the 7s) I hope to be the first in line to acquire it.
Old Nov 10, 2011 | 09:34 AM
ZumnRx8's Avatar
RX8 & RX7 owner
^lol shady ur funny
+1 phil
