shakeyourbrakes
10-17-2011, 11:14 AM
http://www.rx8club.com/picture.php?albumid=3038&pictureid=28802
LED halo headlights -http://i54.photobucket.com/albums/g87/dralla99/rx8/12.jpg
Many of you guys have seen my other post with pics of my LED halo tail lights I have been working on. Here is a basic DIY for those of you who have always wanted to tackle this project, but didnt want to tear up a few tail lights in the process of figuring it out.
What you need..
1. First off, these tail lights do crack..this method makes it a lot less likely, but be aware, one slip up and you can ruin the tail light. Id recommend getting a spare set off ebay, and if all goes well, sell your current tails back on ebay.
2.Dremmel Diamond Cut-off wheel. (see link: http://www.amazon.com/Anytime-Tools-DIAMOND-CUT-OFF-LAPIDARY/dp/B000FJLWNK) This seemed to slice through the plastic the best, no melting, easy to handle, and a tiny separation line unlike other cut off applications out there.
3.Clear silicone
4. 100mm red LED (SMD) Halo/Angel Eye. You could get away with 110mm or so if your not going to use the stock red lens inside the tail light like I did. With the 100mm, you can attach the ring, and still have a gap to replace the red lens on the inside.
My source on ebay was seller ID ipremiertek*co
http://www.hidlightsusa.com/images/prd_R60-15SMD-R_full.jpg
5. LED brake bulbs
Step one- Start dremmeling. Your going to want to go around the perimeter of the clear lens on the front, as close to the black plastic as possible. This will hide most of the cut line. I dont have pics of the process, but its pretty self explanitory when you look at the setup of the tail.
The issue your going to have, is when you get near the key hole on the passenger side tail. The lens is sealed together in this whole section. I found the best way to get around this issue, was to stop, and cut down the black plastic and on the back side of the tail light, avoiding the keyhole altogether. Attached is a pic where you can see the lens separated, with the keyhole section still attached. Sorry its a little blurry but it shows what I mean.
Dont try to cut around the whole lens, thinking this section will pop apart..it wont. You need to leave this connected to the clear lens as one piece
http://www.rx8club.com/picture.php?albumid=3038&pictureid=28804
Due to some heat cutting the plastic, your going to have to actually "pop" the lens off the housing. Heres where it can get tricky..if you didnt cut all the way through the plastic you can easily run into cracking. I used a butter knife, and gradually, and gently put it in along the cut line and popped a little section at a time all the way around the lens. It should eventually pop off as a whole piece, just take your time.
Step two- Now that the lens is off, your going to want to pop the inner red lens off. This is attached by two clips, and a little glue I believe. I used a tooth brush handle and stuck it in the bulb hole on the back of the tail lights. A few good whacks, and the lens popped off.
Step three - Mount the LED smd ring with silicone, drill a small hole on the inside of the ring through to the back of the tail light and run the wires through. If your going to keep the red lens on the inside, put it back on with a few spots of silicone or super glue.
This is the tail with the red lens on the inside remounted over the LED ring.. obviously this would be what it would look like if you were to do it with a stock appearance. The red reflector lens seemed to make the halo look wider, but since I was spraying the tails red anyway, I didnt use it[/B]
http://i54.photobucket.com/albums/g87/dralla99/rx8/3.jpg
broken down, mid process. I sprayed my tails red after, so I decided not to use the red lens to get a crisper LED look.
http://i54.photobucket.com/albums/g87/dralla99/rx8/2.jpg
This is the tail not sprayed red, and without the red lens on the inside
http://i54.photobucket.com/albums/g87/dralla99/rx8/4.jpg
Step four- Seal them up. They should fit together like a glove due to the thin cut line with the diamond cutoff wheel. I used clear weathergrade silicone, and like you would with the headlights, sealed all the way around. The way our tails are mounted, most of where you just cut is going to be hid by the trunk. The part you will see should look fairly untouched if you did a good cutting/siliconing job.
Step five- Connecting the wires. (Ill update this later today with wire colors when I get home and take a look) Your going to splice the wires in with two out of the three wires currently going to your brake lights. The "tail light" function is going to be disabled from your brake lights by disconnecting one of the wires, which will leave your tail bulbs to work only as brake bulbs. Same deal as how your 3rd brake light is wired.
Step six-Replace the brake light with a good LED brake bulb, and install the tail lights on the car.
FYI- If you want them red like mine, Ive had the best luck with Krylon Red stained glass spray from Michaels arts and craft stores... covered by several coats of good quality clear spray.
PICS
http://www.rx8club.com/picture.php?albumid=3038&pictureid=28803
http://i54.photobucket.com/albums/g87/dralla99/rx8/5.jpg
http://i54.photobucket.com/albums/g87/dralla99/rx8/6.jpg
http://i54.photobucket.com/albums/g87/dralla99/rx8/7.jpg
http://i54.photobucket.com/albums/g87/dralla99/rx8/8.jpg
What you need..
3.Clear silicone
5. LED brake bulbs
PICS
