Spacejunky
03-05-2004, 04:17 AM
Now I know there have been lots of posts on this, and I think I have read all of them over the last 24 hours. But none of them really answer my questions. If maybe I missed some of the posts I appologize, please just point me in the right direction if this has been answered before.
What I want to do:
I am trying to wire in two devices into the fuse panel. I am installing a radar detector and a satellite radio unit. I want the power for both items to come from the fuse box, and I am going to run the power lines from there to the top of the dash board where both items will be kept.
What I have:
2 mini vampire cable attachements line those posted by others. Also 30ft of 16 guage wire.
My problems:
It seems that there is not enough room in the fuse panel to attach one of the vampire clips to the upper set of fuses without having problems with putting the door to the fuse panel back on.
Also, which are the best spots to stick each of the vampire cables as to not have any elecrical problems. Such as how high a fuse to stick on the vamp cable.
Is the easiest thing to do to just cut off the attachment that came with the device for the cigarette lighter cable and then attach two wires to that. The hot one goes to the vamp cable, and the other one to ground.
Is there akready a good ground spot near the fuse panel to but the ground wires as to not have to drill a new one?
I appreciate any help that you all can give me.
What I want to do:
What I have:
My problems:
