Adjusting front camber - how to...
Old Oct 5, 2011 | 03:56 AM
legine's Avatar
Hey guys,
I want to adjust the camber by 1 or 2 degrees on the front only.
Is it a difficult job or can it be done at home (without being on a lift)?
Also, will adjusting the camber mess around with the toe?
Cheers, Daniel
Old Oct 5, 2011 | 11:08 AM
MazdaManiac's Avatar
Changing the camber will change the toe.
You need a reliable way to measure the alignment and, though it can be done "in the field" with some pretty simple tools, it takes quite a bit of experience to get the hang of it.
Unless you are planning to be almost constantly adjusting your alignment and you have access to a shop that can, from time to time, check your work, I suggest you just pay a pro to do what you want done.
Old Oct 5, 2011 | 12:12 PM
RX8Soldier's Avatar
Time for boost...
forum member "wrightcomputing" just started (or revived) a thread on how to adjust. Check out his recent activities, and you should find the link
RXFEVER
Aug 29, 2018 10:14 AM
Brokegang
Jan 3, 2016 12:45 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
titaneum_grey
Sep 16, 2015 11:51 PM
