VividRacing.com
03-04-2004, 02:59 PM
I went to the D1 GP this past weekend to check out the drifting and my car was in the K&N vendor area. James, our K&N rep was there waiting for me with the first production carbon fiber heat shield to go with the Typhoon intake. While I polished up the car he instaled the heat shield. Total install time was about 15 min.
Yes, they were supposed to be released already but as you probably know, K&N doesn't specialize in carbon fiber and therefore took longer to produce the piece and it took a few prototypes before the desired shape and fit was created. They are currently still working on these and should be available for purchase by April. It's taking some time and I'm sure some of you will hate me because last time I said it was supposed to be out around mid Feb. Well what can I say. They are planning the price to retail at about $90-100 but that could change as well.
James and I talked about this for a while and he explained the tooling issues and mold making process. We agreed that if they used a less expensive weave of carbon it would keep the cost down and that's what will help sell them. I will do my very best to keep members in the loop on this product.
So far what I've noticed is at idle when the engine is hot or has been running for a while, the hesitation has become less apparent and isn't noticable. The heat shield also uses stock hardware to allow the engine cover to be reused. i will try to get some better pics when the sun shines agian here in Phx. The sides are going to be reinforced so that they are more square instead of bowing in like they are here. Since this is the firs production piece I'm not to worried about that and I'll just pin the sides back to the plastic tray.
http://www.imagestation.com/picture/sraid105/pe0ff527474f996a4cafcb14ea5e6803c/f9718132.jpg
