please help!!
Old Sep 23, 2011 | 10:11 AM
fml's Avatar
fml
Question please help!!
ok i have an 04 mazda rx8 and yesterday my firend was messing around with my amp and sub in my trunk and later when i was driving i noticed my radio head unit wasnt lighting up with the normal red led lights,it doesnt work either, my interior lights that light up when you open your door dont work, my key alarm doesnt work either so i have to lock the car manually at first i thought it was my room fuse i checked it but it wasnt blown but just in case i switched it with another 15 and nothing what do you think it could be please help
Old Sep 23, 2011 | 10:22 AM
Atilla's Avatar
I am THAT guy
^sounds kinda like what happened to me.
unfortunately i don't have an answer at this time because i haven't really had time to check it out further.
Difference for me tho was i spilled liquid onto my amp and shorted out my h/u, all of my audio, interior lights and my alarm.
Have you checked the other fuses?
Old Sep 23, 2011 | 10:25 AM
fml's Avatar
fml
ive checked almost every fuse on the inside cause im pretty sure the problems there i havent really checked the ones on the outside. also the car takes about 2 more seconds to turn on than usual
Old Sep 23, 2011 | 10:50 AM
StealthTL's Avatar
Metatron
What does that mean?
Waits after the key is inserted to light up?
Cranks for two seconds longer than before?
Does your trunk light work?
S
Old Sep 23, 2011 | 10:55 AM
Atilla's Avatar
I am THAT guy
^this is probably a stupid question - but i had my trunk light removed...would this complicate the problem?
Old Sep 23, 2011 | 11:59 PM
fml's Avatar
fml
it cranks for two seconds longer than before and no the trunk light is off ill also add that my windows dont work either
Old Sep 24, 2011 | 12:34 PM
fml's Avatar
fml
FIXED!!!!! it was a fuse in the fuse box in the engine not the inside fuse box
Old Sep 26, 2011 | 01:30 AM
RX8Soldier's Avatar
Time for boost...
^great story! thanks for the update, and thanks for searching
Old Sep 26, 2011 | 02:34 PM
fml's Avatar
fml
your welcome now i just have to see what upgrades i should get since im running completely stock right now
