PAC SWI-PS Question/help
Old Sep 12, 2011 | 08:03 PM
Tmburton's Avatar
Beginning Addict
Ok so here is the issue, today I installed a PAC SWI-PS unit in my 8. I connected the black wire to the grounding and the red to the power and for the white I connected it like the website says to the red/black wire. Well when I goto program the darn thing it doesn't recognize the buttons when i press them. Anybody have any ideas what im doing wrong? all the connections are good. Thanks
Old Sep 12, 2011 | 09:04 PM
kma5783's Avatar
Did you program it for version 3? Are you following the correct programming procedure?
7. Programming the SWI-PS to learn steering wheel control functions.
1. Turn the key to the accessory position (you do not need to hold the Program Button at this time). The LED will flash 3 times. This indicates it is programmed for version 3.
2. Press the Program Button until the LED turns on, then release the button (This will erase all previous learned steering wheel control functions). The SWI-PS is now ready to learn a command from the steering wheel.
3. The SWI-PS must be programmed in the specific order shown in the chart below. If a function is not needed, it may be skipped.
Pioneer, Sony, Advent, Dual, Jensen, Visteon
Programming order for
SWI-PS N/A
1 Volume Up
2 Volume Down
3 Mute
4 Track Up/ Seek Up
5 Track Down/ Seek Down
6 Source
7 Preset Up/ Disc Up
8 Preset Down/ Disc Down
9 Band
New functions added for Pioneer
10 Phone Status, Rev. 1.6.7
11 Answer Call, Rev. 1.6.7
12 End Call, Rev. 1.6.7
13 Voice Recognition, Rev. 1.6.8
4. With the LED on, press your steering wheel button until the light goes out and hold for one second more.
5. Release and the LED should come back on. If it does not please double check all connections and verify for correct version programming.
6. Repeat step 4 and 5 to program additional steering wheel buttons in the order corresponding to the chart above for your SWI interface.
7. If you come across a command in the chart that your steering wheel does not have, or you do not want to program, press the Program Button on the side of the SWI interface.
8. The LED will flash once rapidly and then stay on confirming that you have successfully skipped that command and are ready for the next button.
9. When you are done programming all the buttons, wait for about 7 seconds. The LED will flash 3 times indicating it is done programming. The LED will then flash 3 times indicating the version number.
Old Sep 12, 2011 | 09:33 PM
Tmburton's Avatar
Beginning Addict
Yes I was on #3. I found out the problem I wasn't grounding out the wire on PIN#9 Thanks for the reply though
booboo712
11
Oct 17, 2020 01:37 PM
mushkid
Apr 29, 2011 05:54 PM
and1kidd
9
May 30, 2010 09:19 PM
natron888
Jan 12, 2010 05:29 PM
