Rear fog light and new stalk?
Old Sep 9, 2011 | 01:58 AM
plastic's Avatar
Hi,
Have someone installed the rear fog light and changed the stalk from this:
To this:
Done the wiring and got the indicator light to the cauges? Is there an indicator for the fog light? There's also hazard warning flasher switch but I don't mind about that, switch is already on the dashboard.
Attached Thumbnails Rear fog light and new stalk?-fogswitch.jpg   Rear fog light and new stalk?-withoutfog.jpg
Old Sep 9, 2011 | 02:57 AM
foo77's Avatar
4th batch : Apr 03'
idk, but the stalk look like for front fog light, as for rear fog light there's a switch where the DSC switch at.. if i recall, there's no indicator light unless you bought the car that came with front and rear fog light.. this thread should be front fog light, not rear fog light.. need to see your fog light
Old Sep 9, 2011 | 02:59 AM
foo77's Avatar
4th batch : Apr 03'
btw here's a thread for OEM rear fog light switch and install, should be same for S1 or S2
https://www.rx8club.com/showthread.p...rear+fog+light
Old Sep 9, 2011 | 03:06 AM
plastic's Avatar
Thanks for these. Car is S1 US model without fog lights. I thought the cauges would be the same on all the models, so there would be the indicator. I guess I were wrong. I'll take a look of the thread, rear fog light just needs to be indicated somehow so I guess I'll fix it way it's done on this thread.
Old Sep 9, 2011 | 03:38 AM
foo77's Avatar
4th batch : Apr 03'
what do you mean by cauges? do you have OEM rear fog light or others? need to look at this threads too:
https://www.rx8club.com/series-i-interior-audio-electronics-24/rear-fog-light-install-23677/
https://www.rx8club.com/showthread.p...threadid=15016
Old Sep 9, 2011 | 04:36 AM
plastic's Avatar
https://www.rx8club.com/showthread.php?t=23677
I have OEM rear fog light which I should install.
By cauges ment these:
Old Sep 9, 2011 | 05:18 AM
foo77's Avatar
4th batch : Apr 03'
i see what you mean, a gauge cluster seem you got the OEM, here's a pic from taka thread and his PDF too, hope its help
File Type: pdf
Old Sep 9, 2011 | 06:00 AM
plastic's Avatar
Perfect! Thanks for the installing manual, could be in English thou
RotisserieEngine
General Automotive
11
Aug 6, 2015 06:34 PM
MatthewRJ
Aug 5, 2015 09:24 AM
SayDfuse
Aug 3, 2015 10:41 PM
Stubbs
Jul 28, 2015 09:23 PM
