Custom Exhaust Shrouds?
Old Aug 25, 2011 | 11:56 AM
Nopstnz8's Avatar
Question Custom Exhaust Shrouds?
Anyone made these or had them custom made for cheap? I'm looking for some because I've determined the reasoning for my shrouds discoloring is due to excessive heat from the exhaust. My car is 95% of the time stored in my garage, and I only replaced the shrouds about 7k miles ago, and they are already starting to fade. I've done a lot of backroading in that time though, so the excessive heat from the high revs sounds like the only probably cause.
I know Mazda sells their accessory version of the shrouds, but I'm not looking to drop $200 on something that you'd never even know was there in the first place. If anyone has made their own, or knows shops that can make them, please share. Thanks.
Old Aug 26, 2011 | 06:37 AM
dlum125's Avatar
i'm not too sure if urethane discolors or not, but i picked up some INGS shrouds on ebay for around 55 bucks. the only thing that i would worry about if you pick them up are them melting, but i don't think you'd have that problem with a borla exhaust cause the tips aren't that big.
Old Sep 20, 2011 | 04:12 AM
Nopstnz8's Avatar
^^Yeah but even though they're 3" I believe is the correct size. Anyways, I think from excessive hard driving bringing up exhaust temps, it has slowly caused the shrouds to discolor. If it was from the sun or some other environmental factor, wouldn't the middle piece have the same effects?
Old Sep 21, 2011 | 01:24 PM
hoss -05's Avatar
Lucky #33
You mean these ones? :
Why not try a product like Ultima. I hear it is good at taking excess heat. check it:
http://www.autogeek.net/ultima-tire-trim-guard.html
Old Sep 22, 2011 | 02:32 AM
foo77's Avatar
4th batch : Apr 03'
never have any issue with my custom shroud for 4 years and neither my OEM or Ings FRP shroud have discoloring issue with RB exhaust before..
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
fc2se
NE For Sale/Wanted
Jun 1, 2016 08:55 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
