Removing boot trim
Old Aug 24, 2011 | 02:23 AM
shr3da's Avatar
Removing boot trim
I'm sure there is a thread on pictures on this somewhere but I could not find any, feel free to help direct me.
I want to remove the boot trim, because it's my work car at the moment and I use my boot a lot, and I don't want to damage it and gain a little more space?
Is there much space to be gained by removing it?
any advice appreciated.
thanks.
Old Aug 24, 2011 | 02:50 AM
dmedz8's Avatar
Needs Boost!
not much space... all you do is pull the snapy-tabby things out and remove it.
Old Aug 24, 2011 | 03:25 AM
shr3da's Avatar
okay, is there anything vulnerable that could be damaged, wires or something once it's removed?
Old Aug 25, 2011 | 01:04 AM
dmedz8's Avatar
Needs Boost!
well... I guess pretty much everything... you have the tail light wiring to worry about, The trunk release, and possibly the speakers up top.
Old Aug 25, 2011 | 02:44 AM
shr3da's Avatar
okay just to clarify the only stuff I want to remove is the carpet like material, any wires under there?
Old Aug 25, 2011 | 08:37 AM
firebirdude's Avatar
User and Abuser
Ohhhhhhhhhhh.
You mean the trunk.
The carpet all comes out in three pieces if I remember right. Bottom and the two sides. Like already said, this will leave a lot exposed. Your call if you're ok with that.
You know Mazda makes a cargo tray that protects the base area.
Old Aug 25, 2011 | 05:40 PM
shr3da's Avatar
Yer thanks for the info, I'm not fused about having bare metal exposed, you will never see any scratches once it's back in.
I'm only worried about wires and other things that could be probe to damage once the boot is loaded.
Old Aug 25, 2011 | 07:58 PM
User and Abuser
Well unless you plan on carting cinder blocks around, I think you'll be fine.
Old Aug 25, 2011 | 10:15 PM
shr3da's Avatar
Lol no worries thanks mate, just be putting my work tools in there that's all.
Cheers
Old Aug 25, 2011 | 10:18 PM
User and Abuser
Why not just lay a blanket down or something?
mdl0209
May 23, 2019 05:46 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
