Project/track car, year and trim suggestions
Old Aug 23, 2011 | 04:17 PM
OddEclipse's Avatar
Stay frosty now....
I gotta 10k budget and want a full blown project/track car. I want Pettit to supercharge and tune, not included in the budget. Looking for suggestions on a year and trim RX-8.
Old Aug 23, 2011 | 04:24 PM
Rzoops's Avatar
$10k will buy a pretty clean 04-06 base model without sunroof, but depending on how many miles you find to be acceptable on the engine/chassis, you probably won't have much of anything left in your budget for other essentials. I know I wouldn't want something with 100k miles on it before throwing lots more money on it for a track project.
Without knowing your situation, I would say to either enjoy your current R3 for casual HPDE events or use the $10k towards a Spec Miata or something already prepared as a safe track car.
Old Aug 23, 2011 | 04:32 PM
OddEclipse's Avatar
Stay frosty now....
^ The 10k is for car purchase only. I intend to spend more for mods including supercharging at Pettit racing. My concern is suspension... which model gets me closest with the least amount of mods?
Edit: I do plan on throwing a new motor at it.
Old Aug 23, 2011 | 04:36 PM
dmitrik4's Avatar
please wait for the beep
As long as you buy one with a manual transmission, they're all the same.
The base or Sport models will have less extra weight-adding "stuff" and more room for a helmet b/c of the lack of moonroof.
Old Aug 23, 2011 | 04:38 PM
Rzoops's Avatar
All of the 6-speed models have the "Sport" suspension. Whether they are the Bilsteins or standard Sport package shocks isn't going to make a major difference. I would imagine a so called full blown track car would have some sort of adjustable shocks and ride height adjustment capabilities, which you have to go aftermarket for regardless.
Old Aug 23, 2011 | 04:41 PM
OddEclipse's Avatar
Stay frosty now....
10-4, thanks for your help guy's.
Old Aug 23, 2011 | 04:44 PM
I would look for a clean 04-05 Sport with a blown engine ($5,000ish). Then budget for and engine rebuild/supercharger ($10,000ish conservative).
Old Aug 23, 2011 | 04:52 PM
Highway8's Avatar
Registered RX8 Nut
Buying a car with mods you want will save you a lot of money. You can get a lot of good used parts which will help your budget a lot.
Here is a $20K example https://www.rx8club.com/rx-8s-sale-wanted-43/rx-8-koni-challenge-race-car-221441/
I would forget about the FI until after you have done everything else on the car. Adding FI makes things more complicated and expensive.
For suspension, I would plan on buying a quality coilover or custom valved struts and custom rate springs. Figure $1500-$2K. Less if you cna find a good used set.
Keep your eyes open for used progress tech sway bars. $200-$300.
A car with a blown motor for $5-6k is a good idea. Putting in a fresh motor is a good idea and you can put in a fresh clutch and flywheel while your at it.
Old Aug 24, 2011 | 04:10 PM
kbrewmr2's Avatar
just to confirm - there are no suspension revisions between Series1 & Series2...?
At any rate his current budget is a Series1 car, but... Oh and hold off on the SC until you get some track miles under your belt or if you've got competition of some form being your end goal. Its easier to modify up to a race class than it is to de-mod I feel.
Old Aug 24, 2011 | 04:11 PM
TX
At any rate his current budget is a Series1 car, but... Oh and hold off on the SC until you get some track miles under your belt.
Yes there were changes in the suspension.
Old Aug 24, 2011 | 04:12 PM
kbrewmr2's Avatar
such as?
If it's just spring rates / shocks / swaybars, big deal imho.
Old Aug 24, 2011 | 04:28 PM
TX
such as?
Not sure on specific specs but parts numbers are different and the rear perches on the series II are different.
Old Sep 26, 2011 | 09:35 PM
Rei-teki's Avatar
Suspension
I would suggest an R1 coil-over kit from Eibach. It is height adjustable, and rebound adjustable through internal by-passing. Springs rates and valving can be changed upon request. Plus they will run you about 2300 for a kit which includes front and rear shocks and springs which is entirely worth it
Old Sep 27, 2011 | 04:53 PM
MagnusRacing's Avatar
Just get an early model without sunroof if possible. Also, I THINK that you can even get some that don't have stability control. That is a plus - it's not too hard to eliminate but can still cause some gremlins.
But overall you just need a straight chassis. I got mine as a "non runner" for $4000 at an auction. Turned out the engine was ok (had just sat too long) and I got luck with that. But even with a blown motor it would be a good deal especially if you're planning to build the motor anyway.
Old Sep 28, 2011 | 01:01 AM
hoss -05's Avatar
Lucky #33
I would suggest a 04-05 sport model. They are the lightest of all the rx-8s of any year. They do not come with leather,fogs,sunroofs or DSC.
9krpmrx8
Nov 5, 2015 11:45 PM
D13
Aug 22, 2015 11:42 PM
MolecularConcept
Aug 5, 2015 04:43 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
AussieGray
Jul 16, 2015 03:58 AM
