View Full Version : BC racing coilovers @ Import Image Racing!! **ASK ABOUT EXTREME DROP KIT*************
ImportImage
08-17-2011, 10:57 AM
http://i209.photobucket.com/albums/bb219/bill4458/denniss15.gif?t=1308794533
http://i209.photobucket.com/albums/bb219/bill4458/Nico-Zilvia-2.jpg
CALL 804-690-2452 and mention BILLY to receive special pricing ON RX8CLUB!!!!!
**Remember with Import Image you make YOUR OWN package deal! The more you buy the even great your discount gets :)**
http://i209.photobucket.com/albums/bb219/bill4458/rx8bc.jpg?t=1313692686
http://i209.photobucket.com/albums/bb219/bill4458/rx8bcracing.jpg?t=1313692760
http://i209.photobucket.com/albums/bb219/bill4458/bcinner.jpg?t=1313692796
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/270333_142257795850934_141268352616545_281909_8123 687_n.jpg
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/208207_201099743255558_177480375617495_573214_5550 960_n.jpg
We are the #1 Vendor in the nation for BC Racing coilovers!
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/208207_1937755685128_1279464757_2257081_6974721_n. jpg
BC Racing BR series Coilovers $995 Shipped!! Free Custom Spring Rates as well!!
http://www.scoobyworld.co.uk/catalog/images/br-series-group.jpg
http://farm3.static.flickr.com/2642/4246178950_d70161594c_o.jpg
http://img576.imageshack.us/img576/6231/39548174933819188325100.jpg
http://img341.imageshack.us/img341/7859/73988174933095855064100.jpg
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
http://www.bcracing-na.com/img/products/BR_Type.jpg
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
http://i288.photobucket.com/albums/ll161/tnk210/IMG_2529.jpg
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating.
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 tires with less than 5% deformation.
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight.
- Iron lower brackets on MacPherson struts to ensure rigidity.
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking.
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion.
- Newly developed lubricant oil in shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides the smoothest action and prolongs the lifetime of the pillowball itself.
http://farm5.static.flickr.com/4033/4264940341_0cc1858127_o.jpg
BC Racing RAM type (Inverted) $1225 Shipped!!!
http://www.bcracing-na.com/img/products/RAM_Type.jpg
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
- Inverted Mono-tube shock design
- One year warranty
- Rebuildable
BC Racing ER series $1850 shipped!!
http://www.bcracing-na.com/img/products/ER_Series.jpg
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
- External Reservoir Mono-tube shock design
- 30 levels of damping force adjustment, adjusts both compression and rebound separately
- Twin piston design
- One year warranty
- Rebuildable
http://i48.tinypic.com/axfmp.jpg
Disclaimer- Ad specials not valid on website, only valid by calling 804-690-2452 or 239-540-6385 visa/mc or paypal/googlecheckout.com shipped pricing refers to the 48 states. If you send a payment and live in FL and do not add 6% sales tax, your item will not ship. All returns subject to 35% restocking fee so make sure you want the part before you buy it! if received after 7 days, store credit will be given. after 2 weeks, returns will not be accepted. price subject to change due to manufacturer changing prices.
Questions: Billy (804)-690-2452
(email)billy@importimageracing.com
AIM- importimagebilly
ImportImage
08-18-2011, 09:25 AM
Thursday Bump!
Regards,
Billy@importimageracing.com
AIM: ImportImageBilly
www.importimageracing.com
Direct Line: 804-690-2452
Shop Line: 239-540-6385
Visa/Mastercard/Discover/Paypal and (amex) Google checkout!
200.mph
08-18-2011, 09:34 AM
you dont have any pics of an 8 with your product. ill help you out here. send me your coilovers and ill replace my koni yellows and tien stechs with your stuff. then ill take pics of my car and send them to you this way others can see how they look/work on an 8
ImportImage
08-18-2011, 01:41 PM
Updated!
bose
08-18-2011, 02:47 PM
What's different about the extreme drop package?
ImportImage
08-18-2011, 04:04 PM
Some cars needs either shorter springs and or struts, in this case you would need shorter struts.
bose
08-18-2011, 04:37 PM
What range of adjustability does the regular br series have? How much lower can you go with the extreme kit? How much more would it cost?
The rears in the picture looks like there isn't much room to go lower.
ImportImage
08-19-2011, 10:02 AM
Extreme low kit is no extra cost. Like i said they would use shorter cartridges!
Friday Bump!
Regards,
ImportImage
08-22-2011, 02:02 PM
Monday Bump!
Regards,
ImportImage
08-23-2011, 01:16 PM
Tuesday Bump!
Regards,
ImportImage
08-24-2011, 10:02 AM
Wednesday Bump!
Regards,
ImportImage
08-25-2011, 03:59 PM
Thursday bump!
Regards,
ImportImage
08-26-2011, 01:55 PM
Friday Bump!!
Regards,
ImportImage
08-29-2011, 09:47 AM
Monday Bump!
Regards,
ImportImage
08-30-2011, 01:08 PM
Tuesday Bump!
Regards,
ImportImage
09-05-2011, 10:26 AM
Happy Labor Day, we hope everyone enjoys their day off!
Regards,
ImportImage
09-07-2011, 03:45 PM
Wednesday Bump!
Regards,
ImportImage
09-12-2011, 12:56 PM
Monday BUMP!
Regards,
www.importimageracing.com (http://importimageracing.com)
ImportImage
09-12-2011, 01:03 PM
Monday BUMP!
Regards,
ImportImage
09-14-2011, 01:16 PM
It's Wednesday! Don't forget this week only use Coupon Code: NEWSLETTER on your website for 5% off!
Regards,
www.facebook.com/officialimportimageracing
ImportImage
09-15-2011, 10:55 AM
Thursday Bump! Don't forget this week only use Coupon Code: NEWSLETTER on your website for 5% off!
Be sure check out our facebook page as well!
Regards,
ImportImage
09-16-2011, 04:09 PM
Finally Friday!!!
Regards,
ImportImage
09-26-2011, 10:50 AM
I'm back!
Want to make a combo deal? NO PROBLEM let us know what you need :)
Regards,
ImportImage
09-27-2011, 07:55 PM
Can you PM me next time so i don't miss it?
I'll be in and out of the office today!
Shoot us a PM and we'll get back to you asap
Not sure if we carry something?
Just shoot us a PM and we'll take care of you!
Regards,
ImportImage
09-28-2011, 09:08 PM
Wednesday bump
Regards,
Hurley182BC
09-29-2011, 12:38 PM
How much shipped to 43065? BR-type...I'm not trying to sell a kidney, although I would for the sake of performance lol
ImportImage
10-03-2011, 09:16 AM
PMed!
Ready to make some awesome deals on Monday!
Let us know what you need and we'll get you taken care of.
Regards,
ImportImage
10-05-2011, 02:39 PM
Midweek Bump!
Hit us up for your car part needs :)
Regards,
ImportImage
10-06-2011, 12:57 PM
Who's ready for the weekend?
I know I am! Start the weekend off right with some new parts!
Regards,
ImportImage
10-07-2011, 03:49 PM
Friday never felt so good!
We hope everyone has a safe and wonderful weekend
Regards,
ImportImage
10-11-2011, 12:50 PM
Ask us for suspension and exhaust deals today!
Regards,
ImportImage
10-13-2011, 11:19 AM
We offer multiple part discounts!
Let us know what you need and we'll set you up with an awesome deal
Regards,
ImportImage
10-13-2011, 11:23 AM
Regards,
ImportImage
10-17-2011, 12:17 PM
Happy Monday!
Let us know what we can do for you today :)
Regards,
ImportImage
10-21-2011, 08:47 AM
FREE SHIPPING ALL DAY FRIDAY!!!!
EVERYTHING ON OUR SITE HAS FREE SHIPPING
www.ImportImageRacing.com
Regards,
ImportImage
10-25-2011, 10:37 AM
We do combo pricing! Make your own and we'll get you a great deal :)
Regards,
ImportImage
10-27-2011, 02:48 PM
Need a quote? Let us know!
Regards,
ImportImage
10-31-2011, 03:58 PM
Happy Halloween!
Regards,
ImportImage
11-02-2011, 02:37 PM
Middle of the week!
Come on in for deals during SEMA week :)
Regards,
ImportImage
11-07-2011, 11:46 AM
We hope everyone had a great weekend.
Looking forward to your quotes this week!
Regards,
ImportImage
11-09-2011, 01:11 PM
Midweek bump!
Regards,
ImportImage
11-10-2011, 04:05 PM
One day away from Friday!
Get what you need before the weekend!
Regards,
ImportImage
11-14-2011, 10:31 AM
Hope everyone had a great weekend!
We're ready to rock :)
Regards,
ImportImage
11-16-2011, 01:38 PM
Car parts? We got em!
Regards,
ImportImage
11-21-2011, 11:28 AM
Cyber Monday!
We'll get you the best deals, period :)
Regards,
ImportImage
11-28-2011, 01:41 PM
Cyber Monday round 2!
Regards,
ImportImage
11-30-2011, 10:41 AM
Middle of the week bump!
Let us give you the best deal :)
Regards,
ImportImage
12-01-2011, 02:00 PM
Thursday Bump!
Regards,
ImportImage
12-05-2011, 03:49 PM
Happy Monday!
Get the week started off with some new parts!
Regards,
ImportImage
12-08-2011, 01:17 PM
Need a quote? We've got you covered!
Regards,
ImportImage
12-12-2011, 01:15 PM
We hope everyone had a great weekend!
Let us know what we can help you with today.
Regards,
ImportImage
12-14-2011, 04:07 PM
Get your parts before the weekend!
Regards,
ImportImage
12-19-2011, 01:54 PM
Happy Holidays!
Regards,
ImportImage
12-23-2011, 09:19 AM
Friday before Christmas!
Regards,
ImportImage
12-28-2011, 01:11 PM
Regards,
ImportImage
01-02-2012, 10:46 AM
We hope everyone had a fun and safe New Year!
Bring on 2012 :)
Regards,
ImportImage
01-05-2012, 01:28 PM
Thursday Bump!
Regards,
ImportImage
01-13-2012, 10:41 AM
It's finally Friday!!
Regards,
ImportImage
01-18-2012, 12:37 PM
Regards,
ImportImage
01-24-2012, 02:02 PM
Need a quote? Send us a message!
Regards,
ImportImage
01-31-2012, 01:39 PM
It's Tuesday! Let us know what we can help you with
Regards,
ImportImage
02-13-2012, 01:45 PM
Monday bump!
Regards,
Phone#: 239-540-6385
ImportImage
02-17-2012, 04:00 PM
Friday BUMP!!
Regards,
ImportImage
03-01-2012, 01:47 PM
Thursday Bump!
Regards,
ImportImage
03-09-2012, 01:47 PM
It's Friday!
Regards,
ImportImage
03-22-2012, 03:38 PM
Thursday Bump!
Regards,
ImportImage
04-03-2012, 02:50 PM
Tuesday Bump!
Regards,
ImportImage
04-11-2012, 03:52 PM
Wednesday Bump!
Regards,
ImportImage
04-25-2012, 03:50 PM
Wednesday Bump!
Regards,
ImportImage
05-03-2012, 12:09 PM
Thursday Bump!
Regards,
ImportImage
05-23-2012, 11:30 AM
Wednesday Bump!
Regards,
