View Full Version : What's The Difference From Stg. 2 & 3
Fanman
03-02-2004, 03:56 PM
I understand that the Stage 3 will have the ability to change the maps and will have additional hardware, but what is the difference between hp & tq of a stage 2 & a stage 3 ?
Genom
03-02-2004, 04:00 PM
None. Stage 3 will just allow for boost and multiple maps.
93rdcurrent
03-02-2004, 04:17 PM
Plus you will need to purchase some hardware.
RX-8 friend
03-02-2004, 10:53 PM
Actually, there can be a difference. It depends on how good you are at adjusting things ;) . Stage 3 allows two different things than Stage 2. First, you can have different maps for different situations. Second, you can deal with forced induction, or adjust for "better" intakes or exhausts. Even while you drive, though I wouldn't recommend that. Worse than talking on a cell while driving.
Genom
03-02-2004, 11:25 PM
True, but he asked about torque/HP right off the abt, and I beleive that it's the same. Only changes once you start monkeying around with it, correct?
CanZoomer JR
03-05-2004, 05:27 PM
correct
smrx8
03-11-2004, 11:39 AM
Any hp numbers on the stage 2.i know he said that hes not sure how many hp it would make.HURRY canzoomer i need to know !! before i order, money is on hand :D please!
Omicron
03-11-2004, 11:56 AM
Originally posted by smrx8
Any hp numbers on the stage 2.i know he said that hes not sure how many hp it would make.HURRY canzoomer i need to know !! before i order, money is on hand :D please! Gotta read a bit, this has been discussed many many times in many many threads. But in brief, Stage 1 nets you about 25 WHP, and Stage 2 nets about 40 WHP. Both of these numbers are somewhat higher if you have a good catback exhaust, and better still if you're using a midpipe or high flow cat.
smrx8
03-13-2004, 05:19 PM
sorry omicron your wrong i read somewere that there not sure could be 40 to 55 hp correct me if iam wrong anyone they were waiting to test it.
