Drivers Side Mirror
Old Aug 7, 2011 | 08:48 PM
pfbaseball's Avatar
Drivers Side Mirror
I had a piece of tire smack my drivers mirror..broke the glass and cracked the color molding... Wondering where I would go to get replacement parts... the mirrors are heated BTW.... was thinking junk yard, yet all i need is the mirror piece and the plastic colored piece..(lightning yellow.)
PAul
Old Aug 8, 2011 | 07:52 PM
bumblebeerx8's Avatar
Rear Mount GT35R
I may have every part you need aside from the lighting yellow part I reuse. I only have one glass which I believe is the driver side heated, I would have to check. if you could send me a picture of what all you need and ill check into it all.
Old Aug 9, 2011 | 01:27 PM
pfbaseball's Avatar
Mirror
Nice... I'm needing the plastic piece (bezel?) and mirror glass..
it's the piece the mirror glass sticks to and then that clicks into the assembly and can move...
It's a power/ heated mirror too.....
THanks
BTW, nice paint scheme and I had the same thing (i think) with the water and fan noise (clear water, yes). There's a tube inside the engine compartment on the firewall just above the motor... all you need to do is open it and when I did, lots of water came out.. it was the condensor water from the A/C, and that tube when blocked doesn't allow it to flow out... Anyway, you can check out my other posts and see..
Let me know if you need more.
Tx.
Attached Thumbnails Drivers Side Mirror-p1050218.jpg   Drivers Side Mirror-p1050217.jpg
Old Aug 14, 2011 | 02:41 PM
dezau's Avatar
wtf?
Old Aug 15, 2011 | 08:46 PM
Rear Mount GT35R
i have the power heated mirror driver side and the black plastic the yellow part snaps into. do you need the motor the glass is attaced to (just pushes on ball and socket) or is that still good? send me a pm if you still need them and your shipping info so i can get a quote.
On that second part i am 100% confused as to where it came from and what you are even trying to say.
mitchrx8
Sep 13, 2015 08:05 AM
Tsurugi
Sep 7, 2015 08:27 PM
blkswan
Sep 2, 2015 10:04 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
