New owner :)
Old Aug 7, 2011 | 01:52 PM
D13's Avatar
D13
New owner :)
Just purchased an 04 Touring.
I have an MTX Thunder 6000 8 and am looking at building a slim line box in the trunk passing through the back seat tunnel. The thiele small paremeters indicate I should use a 2" port that is 8.5" long.
So, first question. Does anyone know if you can use a right elbow in the port? My box design is only about 6" deep and I will need to turn the port.
Second. Is there a simple way to integrate a subwoofer into the Bose audio system, or should I plan on upgrading the HU in order to add the woofer?
Thanks,
Attached Thumbnails New owner :)-box1.png
Old Aug 7, 2011 | 09:49 PM
firebirdude's Avatar
User and Abuser
Elbows are no problem. Port length is to be measured down the center of the tube. Port diameter and length will be determined from a combination of enclosure volume and desired tuning frequency. Don't think what's written in the owner manual are hard and fast rules. I suggest some box modeling software.
Use a line output converter off the rear speakers. Then install amp and sub as usual.
Old Aug 9, 2011 | 10:04 PM
atruerx8racer's Avatar
AJ- THE True Rotarian.
Welcome to the Rotary addiction! Make sure you keep your oil tip top and your coolant full. And also keep up with your ever 30k maintenance. Rotary4LiFe!
Old Aug 9, 2011 | 10:05 PM
ZumnRx8's Avatar
RX8 & RX7 owner
welcome!
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Quiggs321
Sep 30, 2015 05:34 PM
FubarI33t
Sep 28, 2015 08:45 PM
