View Full Version : Hood struts DONE!
StealthTL
03-01-2004, 09:37 PM
After two other attempts at gas lift hood struts, I have succeeded! For a total outlay of about $32 (including the two failed attempts!)
Most gas struts have about 50 lbs of force, WAY too much for the 'little-girlie' hood of the '8......I found some more delicate ones at my local surplus joint, with around 20 lbs of push.
They mount to a bracket from the hinges, and anchor to the body at the panel bolt by the shock tower. The brackets and mounts are a little over-built, but better that way than flimsy.
More importantly, they are 100% BOLT ON! The stock struts, and all the aftermarket kits I've seen, need new holes, rivets, threaded inserts etc.
The cheesey hood prop is GONE!
S
brothervoodoo
03-01-2004, 09:42 PM
Very cool, any chance in writing a DIY??
RX8_GT
03-01-2004, 10:09 PM
DIY Please !!! and the name of struts themselves and supplier. The stock struts are $$$$.
John
XDEEDUBBX
03-01-2004, 10:39 PM
i 3rd that...
MaRX8
03-01-2004, 11:46 PM
Beautiful Job, Yes please give us the Details...
D MENAC 7
03-01-2004, 11:52 PM
Excellent, I was waiting to see you perfect it with baited breath and the willingness to run out to the local parts place. I saw your last attempt and thought this is one that when it is done I want to do. THANKS!
StealthTL
03-02-2004, 12:07 AM
The hinge end is cast aluminum, cut to extend forward over the rubber seal between engine compartment and wipers. Bolt holes to match the hinge bolts. The stock bolts are huge, over an inch long, lots of room for added metal.
You could probably do a lot better job of matching color too, it is the only red I had, and is ALMOST, but not QUITE, exactly the wrong shade.....
S
StealthTL
03-02-2004, 12:10 AM
There is only one good mounting bolt on the fender, it IS a little far forward, but works. The bracket has the 'L' offset, so that the bolt will bring the forces right back in line with the bolt....no twist.
S
StealthTL
03-02-2004, 12:21 AM
The struts are probably going to be the hardest parts to find.......
The Symbol on them looks like a christian cross in a circle, don't know what company that is. Writing is the usual 'warning:high pressure, do not bite' stuff....Logo says either "STABILUS" or "STABIL U.S." (very small) Colmar Pa. USA.
#'s on strut - 9L28630 C239/94
Hope someone can find more info from that, I bought the last two locally, so no need to even ask me!
S
Omicron
03-02-2004, 01:14 AM
Bought them locally where? Auto parts store? Home Depot? Please elaborate.
And, can you provide non-mounted pics of the brackets you fabbed up?
Actually, this is just begging for a DIY thread...
StealthTL
03-02-2004, 12:43 PM
Bought at a local chain of army surplus places - Princess Auto.
Maybe someone can contact the maker for a retail store?
S
RX8_GT
03-02-2004, 04:40 PM
StealthTL
Please tell us the part # - I love Princess Auto - visit every time I get up to Canada.
John
RX8_GT
03-02-2004, 04:42 PM
What I mean is Princess Autos #
John
StealthTL
03-02-2004, 04:51 PM
Sorry, neither of them had a stock code on them, they where just in a clearance bin at the back, with just a price.
I WILL definitely look to see if they are on the shelf, next visit.
S
r0tor
03-02-2004, 05:32 PM
whats the approx length of the shocks? My fathers Explorer came with them - they look about the right size and are as cheap and easy to find as dirt.
can you get some more detailed shots on the mounting hardware you created?
StealthTL
03-02-2004, 06:00 PM
Just posted a more complete write-up, in the TECH/D.I.Y. section (didn't know we had one!)
S
