View Full Version : Rx-8 Cvt
Supercharger
01-26-2003, 09:37 PM
Let's hope that Mazda will replace the 4-speed automatic transmission with a CVT in the future.
Continuously Variable Transmission offers good acceleration and improves fuel economy.
Puppy1
01-26-2003, 10:11 PM
CVT's are better for engines with very narrow powerbands. Since the Renisis has a very wide powerband, a CVT is not a good way to improve performance or economy.
I personally think the best idea for Mazda to explore would be a hybrid engine that would allow more low end torque, with increased fuel efficiency. Check out the NSX hybrid concept.
Hercules
01-26-2003, 10:41 PM
FWD :\
lefuton
01-27-2003, 12:27 AM
correct me if im wrong but i was under the impression that cvt's were restricted to lower output engines, like the equivalent of your typical 4 banger or was it ~200ish horsepower?
wakeech
01-27-2003, 02:55 AM
there isn't really a theoretical limit if you're trying to design a car within reason (i'm not saying that you could produce a CVT for a 3500hp top fuel dragster or whatever...), but how much weight and cost would go into making one for a 300hp car??
i wouldn't doubt, though, that a CVT is a far better solution than the old 4 speed autos, as far as mass and efficiency go... but they are pricey. hmmmm... also, there's the problem of these transmissions handling revs... i don't know much about the way in which they work: would it pose a problem to have such a wide range of rpm operation (ie: about 6000 rpm)??
cueball
01-27-2003, 02:34 PM
That was true until recently. CVTs are now able to handle HP north of 200. I think the nissian Morado (sp) has a CVT and more than 200 HP. Correct me if I am wrong though.
Magnus Berglund
01-28-2003, 12:44 AM
THe Williams F1 team made one in 93 I think..
Worked really good but sounded very strange.. *s*
It was banned before they ran it in a race..
//magnus
b2k2000
01-28-2003, 04:19 PM
Um, ok coming from the snowmobiling world, I have personally worked on a 332.3hp (we have a Dyno) Drag snowmobile, since that is where the CVT came from (they are the same thing) I know for a fact that they can handle well over 300hp. The ones on snowmobiles are typically designed for the engine to mainly run at a constant rpm (most effecient) but work well at all rpm's. They work by having a "drive clutch" and "driven clutch" one is spring tensioned closed "driven", the other is open "Drive", when the engine's rpm's increase, weights swing out and close the "drive clutch" which forces open the driven and the friction also spins the driven and ultimately the wheels/track. The higher the rpms, the more the drive opens and the more pressure on the driven and the more the gearing rations change. Hope that was not too confusing but that is the basics of it. There are alot of other factors also, like spring tensions, weights, angle of the helix (the path the weights swing out on), etc. If anyone has any specific questions on how that clutch works post here and I will try to answer as best I can. Remember all my knowledge comes from snowmobile clutches so take that into acct when asking.
hajami
01-28-2003, 06:34 PM
The new Audi A4 has a CVT available with the 3.0 V6 wich is rated at 220 hp.
The only problem with CVT's is almost all the ones in use now are front wheel drive only.
MikeW
01-28-2003, 09:36 PM
Nissan has a longitutinal CVT. The Xtroid.
http://www.nissan-global.com/GCC/Japan/NEWS/19991001_0e.html
http://autozine.kyul.net/technical_school/gearbox/tech_gear.htm#ExtroidCVT
Supercharger
01-28-2003, 10:57 PM
CVT Car model Engine Max. Torque
Audi A4 3.0 221 lb-ft
Nissan Murano 246 lb-ft
The max. torque of the Renesis is 160 lb-ft. Torque capacity is not an issue for the rotary.
In fact, a good CVT can handle a Vortech supercharged Renesis; as long as the boost is kept below 6psi.
A CVT compensates for the Renesis's lack of low end torque by keeping the engine operating in its powerband. In other words, you can tune a supercharged rotary for a narrow powerband.
A CVT is lighter than a conventional gearbox. The weight saving is another bonus.
wakeech
01-29-2003, 04:07 AM
alright, sure. i'm impressed with that torque handling capability: can it handle the rev's though?? 9k input revs is a lot... and who would want to be at 60 degree throttle all the time anyways to keep the engine in its "optimal performing range"?? i mean, sure, you'd get great get-up-and-go... how well could this system really save you gas by keeping revs pinned at 2krpm and just decreasing the ratio?? basically, what i'm getting to is "Can a CVT really span the useful strata of gearing ratios that your average banger box can??"... i wouldn't bet on it.
Although a CVT might be "lighter than a conventional gearbox", at what cost level, what design, what materials, how many cogs?? i'm nearly positive that if cost was equal (not only in manufacturing but also R+D) that you could certainly make a synchro'd manual tranny that weighs much less than a CVT.
:D i'm not against them, just trying to come up with some interesting counter thoughts, trying to see the comprimises (as in engineering they are ever present).
hajami
01-29-2003, 11:05 AM
Actually, a regular manual gearbox is lighter than a CVT.
Audi A4 1.8T:
5Spd FWD - 3252 lbs
CVT FWD - 3362 lbs
http://www.audiusa.com/features_specifications/0,,contentType-26_modelId-200301_status-P_countrycode-1_,00.html
wakeech
01-29-2003, 02:02 PM
one can't really say it's a universal truth, but yeah, i'm sure it'd be easy to make comparable transmissions of the manual sort lighter, if not also smaller, than a CVT... that said, it may be worth that extra mass in its advantages ?? it's all a big trade off. :)
MikeW
01-29-2003, 06:24 PM
Audi's multitronic ratio span has exceeded 6:1, and they are up to almost 6.5:1 in the 'version 2' in the A4 cabriolet
b2k2000
01-29-2003, 08:22 PM
It will handle the rev's, the snowmobile could spin 14k rpm's (it was a 2stroke!) reliably, just had better drag racing capabilities spining at 9800rpm's. The only issue I can see is on snowmobiles the belts are worn out in 200-300 miles, so the belts in the cvt's for cars are different somehow to last longer.
Supercharger
01-30-2003, 07:53 PM
Toroidal CVT A highly efficient transmission is a significant factor in reducing fuel consumption of automobiles. An automatic transmission that skilfully draws the power out of the engine, faithfully matching the driver's intentions allows every driver to enjoy driving in comfort. Starting from this premise, Mazda has conducted the R&D of Toroidal CVT (Continuously Variable Transmission) as a next-generation transmission, which is highly efficient, lightweight, compact and can deliver larger engine output.
The Mazda Toroidal CVT combines the half-toroidal CVT with a geared neutral starting system. This highly efficient system is an ideal transmission for FWD vehicles, delivering excellent response, quiet operation and superb fuel economy. Combined with a 3.0 liter engine, it achieves about 20% improvement in fuel economy in Japanese 10-15 mode compared to a current 4-speed automatic transmission. Half-Toroidal CVT In the half-toroidal CVT, a large force presses a semicircular disc against the power roller, and the resulting shearing force of the ail film squeezed in the space between them transmits power. Changing the effective radius of the contact point enables the gear ratio to change continuously, resulting in step-less gear shifting. An exclusive traction oil is used for lubricating the system; when this oil between the disc and power roller is placed under high pressure, its viscosity rises momentarily. As the oil becomes more viscous under pressure, it becomes harder, and transmits the power by the shearing force. An electro-hydraulic control tilts the shaft washer of the power roller, changing the effective radius of the contact point and making smooth, quick shifting possible.
In addition, the half-toroidal CVT has these key benefits: - It is possible to transmit high torque loads because of the high performance traction oil and high-surface-pressure material used in the disc and power roller. - It is very efficient because it does not require high hydraulic pressure to transmit power like a metal belt CVT. - It is much quieter than a metal belt CVT because power is transmitted via a smooth rolling contact surface and the shearing force of the oil. Geared-neutral starting system This transmission system uses a geared-neutral system. This dual-mode system which uses the CVT and planetary gears in low-speed mode, and the CVT alone in high speed mode. In low-speed mode, the planetary gears' differential function provides a large reduction gear ratio and also increases torque, for excellent starting acceleration. Because the engine can run at low rotational speeds, this system achieves excellent fuel economy and quiet operation. Switching between modes is automatically controlled by a computer, which synchronises the two clutches, one for low speeds and one for high speeds. The neutral-geared system also eliminates the need for a torque converter, further enhancing the overall compactness and efficiency of the car.
System torque capacity 300N - m
Reduction speed ratio Forward infinity to 0.415Reverse infinity to -2.789
Final drive gear ratio 4.375
CVT mechanism Dual cavity type, half-toroidal CVT
Starting system Geared neutral type
Shift control device Electronic hydraulic pressure control
Supercharger
01-30-2003, 08:09 PM
CVT diagram
http://www.rx8club.com/attachment.php?attachmentid=881&stc=1
Supercharger
01-30-2003, 08:12 PM
Diagram 2
http://www.rx8club.com/attachment.php?attachmentid=882&stc=1
Supercharger
01-30-2003, 08:14 PM
http://www.rx8club.com/attachment.php?attachmentid=883&stc=1
wakeech
01-31-2003, 01:24 AM
holy shit, i'm impressed. if they could make those things smaller, lighter, and cheaper, it'd be all over!! :D wow. i'm sold.
Supercharger, engineers and fans of the CVT should give you a fricken' medal, man. great posts.
that said, i'm sure that manual trannies will always remain light enough, cheap enough, practical enough, and fun enough that there will always be a market for them; however, the 4 speed auto, and the recently-developed 5+ speed autos have their days numbered. :D
Supercharger
02-02-2003, 10:47 PM
The engineers at Mazda deserve a medal. They know how to build affordable sportscars.:)
Mazda CVT's torque capacity of 300Nm = 221 lb-ft
Supercharger
02-03-2003, 07:23 PM
http://www.torotrak.com
MobileMan
02-26-2003, 11:49 PM
Great posts, Supercharger!! I have been interested in these for years...now the technology and designs are catching up to the concepts.
The reason high rpms have been a problem with automatics was based on torque converter stator issues. Assigning a proper stall speed for an engine with a high rev powerband made streetability problematic. A CVT doesn't have the same design challenges.
Supercharger
02-27-2003, 09:54 PM
A good reference:
http://www.me.utexas.edu/~lotario/VSDC/leks/4ModVehPerformance2.pdf
PsYcHo_Pilot
02-27-2003, 10:35 PM
good stuff Supercharger, how much do these things weigh ?? i'm guessing too much, or else they'd be in the rx8
Supercharger
02-28-2003, 10:31 PM
Mazda's CVT is designed for front wheel drive cars.
Supercharger
03-02-2003, 10:09 PM
Mazda could build a mid-engine RX-7 and use the CVT gearbox.
zoom44
03-07-2003, 05:31 PM
Supercharger:
i just read in one of the mags yesterday(sorry don't have it in front of me) that an american company (ford? sorry again don't have it in front of me) is going to put a CVT in an all wheel drive SUV. do you know if this has been done before or what the setup would look like?
CraziFuzzy
03-07-2003, 06:40 PM
Just think about the efficiency you could get by building a small gas turbine powered car with a CVT in it. A small turbine is probably the most efficient gas engine (power/consumption) possible when at a constant RPM, so imagine piping that lightweight, low consumption, power through a CVT. This has been a big thing keeping anyone (even hobbyists) from making a turbine powered car. Sure, there have been turbine powered cars based on the actual thrust, but this is incredably inefficient. The turbine is VERY efficient on the shaft... hmmm... just some off the wall brainstorming.. hehe
EDIT: And you think a rotary sounds cool! hehe
CraziFuzzy
03-07-2003, 06:58 PM
hehe, I just found a 400LB gas turbine that makes between 900-1200 HP... hehe... of course, you have to gear it down from 43,400rpm.... hehe
Supercharger
03-08-2003, 09:10 PM
Zoom44:
Ford and Torotrak developed a CVT for the Expedition SUV.
Torotrak's IVT has a very high torque capacity. Ford Expedition's 5.4-liter V8 engine produces 260 hp and 350 lb-ft of torque.
Check out this link for more info:
http://www.torotrak.com/articles_press.html
Driving Impression
The main benefit of the revolutionary technology is improved fuel economy. Figures show savings of up to 20 per cent over a standard four-speed automatic, thanks to a complicated system of gears that, as the name suggests, offers a near-infinite number of ratios. Similar to – but more robust than – a CVT box, the IVT copes with high performance engines. However, this means nothing if the system feels horrible to use. So we got behind the wheel of a Ford Expedition 5.4-liter V8 fitted with the new device to check it out.
Gearchanges are seamless. Floor the throttle, however, and engine revs climb steadily to peak power, rather than racing skywards as with a CVT. As a result, the IVT gives a better driving experience. Another feature is its high overdrive – 80mph is possible at only 1,000rpm. But it doesn't need a clutch or torque converter to pull away from standstill. Because fewer slipping parts mean less wear, the unit should be maintenance-free.
On steep hills, we could use the throttle to hold the big Ford steady for as long as we wanted. By backing off, it was possible to control the rate at which it slipped back – something that would scupper most other automatics.
Supercharger
03-08-2003, 09:16 PM
In a Torotrak IVT the driver sets the wheel torque demand, the computer sets the engine torque and speed, resulting in ratio.
High performance with economy
By responding to driver demand - expressed through the accelerator pedal - and monitoring the engine, vehicle and transmission, the software algorithms generate control decisions for the engine throttle and transmission hydraulic system. This level of control can produce high performance when required, coupled with economy at all other times.
Flexibility of powertrain design
With the Torotrak IVT the driver 'drives' the transmission rather than the engine. This releases the engine from the constraints of driveability, allowing it to be run for optimal economy, emissions or, when required, ultimate performance. Consequently the Torotrak IVT provides ample opportunity for manufacturers to meet the ever more demanding legal requirements for fuel economy and emissions without sacrificing driveability or performance.
Benefits of optimum control
In essence, the degree of control freedom the Torotrak IVT offers ensures the engine can always be run at its optimum operating conditions. This results in:
Improved economy
Better performance
Reduced emissions
Smoother operation
Lower overall noise levels
This IVT layout (as shown in the picture) is designed for front-engine rear-drive cars (ie RX-8). :)
http://www.rx8club.com/attachment.php?attachmentid=1318&stc=1
Supercharger
03-08-2003, 09:26 PM
The good news for us is that a Japanese gearbox company (Aisin) has a Torotrak license. That means Mazda could ask Aisin to design/manufacture an IVT gearbox for the RX-8.
An IVT-equipped RX-8 can accelerate faster than a 6-speed manual RX-8 in rolling starts - such as Car&Driver magazine's top gear 30-70mph tests.
P00Man
03-09-2003, 01:37 AM
so that ting creates rations per rpm? meaning that at each new rpm, it's creating a new ratio. this is the only way i could see the driver inputting torque demand, through mashing the pedal. unless its some other way, like a GUI or something.....do you know how the driver inputs torque demand?
________
Maryjane (http://maryjanes.info/)
Supercharger
03-09-2003, 10:16 PM
Driver input is the same as any car - the gas pedal.
P00Man
03-11-2003, 08:29 PM
thats what i figured
________
Wendie 99 (http://www.lovelywendie99.com/)
Supercharger
04-08-2003, 01:18 AM
This article compare CVT against conventional gearbox.
http://www.v8914.com/Horsepower-v-torque.htm
wakeech
04-08-2003, 01:30 AM
ahahaha... thanks for the link... this is the page that Rich'd always use to try and educate the low-torque naysayers in the early days of this forum *bookmarks page*
Lensman
04-17-2003, 04:32 PM
Just in case you think that turbine powered cars are a radical new idea the gave a look at this. (http://www.rover.org.nz/pages/jet/jet5.htm)
globi
02-24-2007, 07:18 AM
CVT in action (click on the video):
https://www.pmtuning.co.uk/News.htm
