Car Pc issue, please help.
Old Jul 20, 2011 | 02:13 AM
XvPSI's Avatar
Hey guys Im putting in a carpc in place of stock navi, however i can not figure out if i will be able to connect my pc audio to the head unit. Is there a way to do this or will the factory headunit be completely useless after the car pc install?
Old Jul 20, 2011 | 06:54 AM
XvPSI's Avatar
P.S. I searched the forums and found out about CAR2PC however it is not compatible with firmware 9.81 and my head unit is running 9.82 so I believe it would not be compatible either because it is only .01 difference.
Old Jul 20, 2011 | 12:16 PM
Mike-RR's Avatar
Hello, I'm using the Axxess interface and my firmware is 10.01
Regards,
Mike.
Old Jul 20, 2011 | 12:29 PM
Z0oMzo0m's Avatar
GROM aux port
Old Jul 20, 2011 | 01:15 PM
hakuna matata!
you can use an auxilliary in interface such as the Dice R2 or Grom or you can take this opportunity to upgrade the factory Bose amplifier (if you have it) and that should have it's own aux-in.
Old Jul 20, 2011 | 01:58 PM
XvPSI's Avatar
thanks guys appreciate the help
Dokuji
Nov 1, 2016 02:51 PM
9krpmrx8
Nov 5, 2015 11:45 PM
thewatcher101
Aug 4, 2015 10:42 AM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
