Wiring harness for base head unit?
Old Jul 20, 2011 | 01:32 AM
pegasixi's Avatar
Hi there,
Sorry if this has already been discussed but I'm such a newbie at this audio stuff that I wouldn't know it if it reached out through the screen and poked me in the eye. TT I'm trying to learn tho!
So basically I'm looking for some kind of adaptor to interface between my stock (base) headunit and the wiring harness because I'd rather not cut any wiring when I hook up a 4 channel amp through a LOC. This way, I could hack away at this "placeholder" and always remove it later when I revert back to stock. Does such a thing exist? where can I find one?
Thanks in advance!
Old Jul 20, 2011 | 01:24 PM
firebirdude's Avatar
User and Abuser
I have seen harnesses like this before, but certainly not for the RX8. However you could easily just you the Metra 70 and 71 series harness to make one yourself.
Metra 70-7903
Metra 71-7903
One male end plugs into your stock non-bose radio and the female end plugs into your existing wiring harness. Then just solder the leads you're not tapping together (+12 constant, +12 ignition, etc). Use the speaker leads as you need em. When you're ready to remove your custom additions, just unclip and return to stock.
RevMeHarder
Jun 1, 2026 02:30 PM
DVerdeyen
Sep 13, 2015 11:19 AM
mattymack
Sep 6, 2015 10:33 PM
iwannarun
Sep 6, 2015 01:37 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
