{WTB} Front Driver Side Wheel Hub Assembly
Old Jul 12, 2011 | 07:12 AM
j.demontis's Avatar
ON Front Driver Side Wheel Hub Assembly
Category: Steering & Suspension
Price: $0
Location (US State/Canada/Int): Canada
Hey Guys. My brakes have been making a weird sound recently when ever I apply them lightly and im pretty sure my wheel hub is warped. Im looking for the front driver side wheel hub where the studs are pressed through. Please let me know if you have this item and how much you want. I live in Toronto so ill pay for shipping.
Old Jul 12, 2011 | 07:27 AM
fuztupnz's Avatar
Phone Booth'd
Why would you think that your hub is warped. Unless you were in a serious accident or drilled a curb, I doubt that's the case.
What kind of noise is it. Have you checked that your pads aren't down to the warning tabs? Have you turned your rotors. Have you checked that your caliper slides aren't sticking?
Check that first before buying a new hub/knuckle assembly. At the very worst, you have to buy new pads and/or rotors. Most likely you can just have the rotors turned down.
Old Jul 12, 2011 | 07:59 AM
j.demontis's Avatar
Rotors and pads were changed recently and yes my brother did his a curb on the front driver side and I know how easy those hubs can be bent. The noise like something being squeezed and again only happens when I apply the brake slightly, as I brake harder it goes away so it must be the wheel hub is warped slightly.
Also recently I had some front driver side wheel problems and I had to use a slide hammer to remove the press fitted hub from the assembly so im sure there was some damage done there.
Old Jul 12, 2011 | 10:19 AM
gotrx8's Avatar
MO
I've got one..... I've got a whole car im parting out. Ill sell you the unit as a whole for a measly 100 bux. car has 83,000 on it. Its on jack stands right now.
you would have to be responsible for shipping though. I am PAYPAL verified also!
Let me know if you need anything else.
vapor2
Oct 8, 2015 02:08 PM
SayDfuse
Aug 3, 2015 10:41 PM
MarkX
Jul 31, 2015 07:50 AM
reverse01134
Jul 16, 2015 10:27 PM
