Has anyone tried the Tornado Fuel Saver?
Old Feb 29, 2004 | 07:03 AM
JimJimElf's Avatar
Question Has anyone tried the Tornado Fuel Saver?
With everybody complaining about poor gas mileage has anyone tried using the Tornado fuel Saver? Just wondering, please let me know if are using or have used and what your results are.
Old Feb 29, 2004 | 07:28 AM
cgrx's Avatar
DRIVEN
I've heard they are a waste of money
Old Feb 29, 2004 | 10:18 AM
Gord96BRG's Avatar
Anyone who has ever done a proper dyno test on a vehicle with before/after runs for the Tornado has ALWAYS found that they either made no power or lost power.
They're just an intake restriction, and the swirly air theory is pure BS. From an engineering standpoint instead of a marketing hype standpoint, they're completely useless, bogus, and fraudulent.
Regards,
Gordon
Old Feb 29, 2004 | 10:24 AM
jimbo912's Avatar
Hey Gord,
Completely off subject, but I noticed you are 44 and also drive an Audi Quatro. Me too,hmmm. I'm the 245(fat) snow tire 8 driver.
Remember,
Jimbo
Old Feb 29, 2004 | 10:25 AM
jimbo912's Avatar
Also have Ti Grey stick
Old Feb 29, 2004 | 12:15 PM
Omicron's Avatar
Try a search on "Tornado" but Gord summed up the results (or lack thereof) nicely. As usual.
Old Mar 2, 2004 | 02:29 PM
Chieferx's Avatar
Ok you are wrong, the car was on the dyno with and with out and yes it made around 10 whp more than stock and I was present at Peter Farrel Super cars So if you have not seen it on a dyno or have had a bad experience with the Tornado with another vehicle then I can trully say you don't know what you are talking about. Bye the way show me your dyno results with and with out the tornado, in fact I will give you mine for testing then you will see the difference.
Old Mar 2, 2004 | 03:09 PM
DisneyDestroyer's Avatar
Careful, I bite!
Yep, DontBeARikki put on a Tornado and did get improved power.
People promised(threatened?) to do their own investigation to determine why, but nobody has that I've seen. The best guesses (that I remember) were that it fooled the air sensors into thinking there was a bit LESS air, so they gave less gas - accidentally providing a benefit of thinning out the mixture.
Old Mar 2, 2004 | 03:10 PM
islandsoon's Avatar
Chieferx...
You wouldn't also be Broke_Apex_Seal would you?
Or maybe Dont_be_a_Rikki?
Your 'voice sure sounds familar.
Tom
Old Mar 2, 2004 | 05:11 PM
Genom's Avatar
Not so Super right now
Several people decided to roder them at one time and where going to report back and never did. We have had 2 people that I know of put one in and both claimed to feel more power but there where no dyno's done. Nothing much ever came of it afterwards. I am skeptical about it, but am willing to change my mind if I see a back to back dyno done with one
Old Mar 3, 2004 | 05:19 PM
Painless's Avatar
On their website, they have a little disclaimer which says the average is 1-2 mpg, though on the RX-8 that might be nice, as it drains the fuel pretty quickly.
Anyone tried any exhaust kits that have produced measureable differences in MPG?
Old Mar 4, 2004 | 11:07 AM
Broke_Apex_Seal's Avatar
I will repost these dynos so you can see the difference in power.
With out tornado (Stock)
Old Mar 4, 2004 | 11:08 AM
With tornado (Stock with Tornado only)
Old Mar 4, 2004 | 12:11 PM
shaunv74's Avatar
Power!!
Do you have a dyno test with the Tornado on with Engine RPM on the X axis? could you post that if possible. It is more difficult to compare the power curve with two different x axis. Or dow you have a graph with the two overlaid on top of each other? A 10 whp max gain is very impressive.
Old Mar 4, 2004 | 02:26 PM
well I have to go mess with it tonite. This was on the old CPU dyno jet but I know I have another set of dynos with and with out tornado both haveing a mid pipe I think it was 198 and the other was 190 or so.
Old Mar 5, 2004 | 01:26 AM
Painless's Avatar
So was there a concurrent jump in fuel efficiency, the main idea of this gadget?
Old Mar 5, 2004 | 01:48 AM
winter's Avatar
Hey Painless, wanna buy a rock that keeps away tigers?
Old Mar 5, 2004 | 11:48 AM
Chieferx's Avatar
No I am not Broke_apex_seal or Dontbe arikki. Anyhow we do know each other, and he is a good source for any car info
Old Mar 5, 2004 | 12:38 PM
bureau13's Avatar
Didn't you then put on a catback or intake or something and have detonation issues? I remember something like that but I'm too lazy to search for the original thread. However, that did seem to support the theory that the power gains could be due to the Tornado messing with the air seen by the MAF sensor, causing a leaner mixture. I'm not going to dispute the dyno results, but I certainly don't believe you're getting power gains because the device is acting as designed. There have been plenty of other reports using different cars that showed no appreciable difference. That said...even if its an accidental gain, its a pretty cool find (assuming you don't get into trouble with a leaner mixture).
I wonder if there's any impact to this from the new ECU program that's available...it reportedly leaned out the midrange.
jds
Old Mar 5, 2004 | 12:57 PM
jds
I am pretty sure this TFS is just fooling the MAF plain and simple it just happends to work well on the 8. Take it as a good thing. Why do people want to be so negative when it works in are benifit? Also my first CAI design SUCKED but then revisited the idea and found my problem. I have over 25 dyno pulls on my 8 and all different types of mods and the TFS has been the MOST increase in RWHP
Old Mar 5, 2004 | 02:22 PM
wakeech's Avatar
mostly harmless
yyyyeah, so you could use something which hinders airflow to fool the computer to make a little more power, or you could get something (say like Maniac's E-Manage solution, or Canzoomer's all-in-one unit) to tune the A/F ratios and ignition timing to better suit performance and make even more gain...
Old Mar 5, 2004 | 02:43 PM
islandsoon's Avatar
The good thing about the Tornado, that Broke_Apex_Seal is suggesting, is that it is a small investment and he doesn't have any reason to promote the thing. If it works great, even if it is an accident. The problems I have are the issues he reported last year with other mods not working well with the Tornado. Say you are happy as a couple of clams with just the Tornado installed, doing its job fooling the MAF, 10 extra HP, no troubles. You get a new flash, lets just say to "L", and every melts at 3750 rpm. You get a new air intake, every things melts at 5129 rpm. Damn, hard for us average Joes to risk melt downs.
Tom
Old Mar 6, 2004 | 12:25 PM
DBAR's Avatar
Tom
My point exactly. Cheap and easy HP IMO.
Broke_apex_seal
Old Mar 6, 2004 | 12:27 PM
DBAR's Avatar
Maniacs E-manage or canzoomers ECU's are nice I guess but I have yet to see a dyno over 200 RWHP. I have made 198 with out it. How come no dynos have been posted making 200plus.? Want more power and better tuning go TEC 3 and run closed looped with PFS wideband and watch the gas mileage go up. I mean come on here dont knock a good product.
Mr. Negative
Broke_apex_seal
Old Mar 7, 2004 | 11:50 AM
islandsoon's Avatar
DBAR...
You change your ID, no longer going to use Broke_apex_seal?
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
