How do you lace the ballast wiring through the headlight assembly?
Old Jun 30, 2011 | 03:03 PM
Donkeypunter's Avatar
I'm quite thankful for everyone's help as far as getting the front bumber off and where and what parts to get, but not I'm a bit stuck...
I had a crack in my headlight assembly and water leaked into the ballast and fried it. Bummer. Ordered new parts separately (couldn't find a new assembly with an attached ballast) and now I'm in a bit of a predicament:
[IMG][/IMG]
[IMG][/IMG]
As you can see in the first picture, the old assembly has the ballast laced through. The new one (in the second photo), not. The opening is far too narrow to simply shove the part through, so what should I do?
My initial thought was to stick the new assembly in the oven and open it up, lace in the ballast, and then stick it back in the oven to reseal. Problem with that is whether or not the oven heat (at 200-220 degrees) will destroy the ballast.
HELP!
Old Jun 30, 2011 | 07:01 PM
Mazmart's Avatar
Your thread is in the wrong section as 'GENERAL AUTOMOTIVE' is for everything automotive not related to the RX-8.
Do not heat up the light to do it. It does squeeze through.
Paul.
arexatemate
Oct 9, 2015 06:23 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
