Jedi54
06-30-2011, 12:12 PM
Just noticed this when replying to a thread and trying to color code some of my responses.
The first line I tried to code with 'sea green' worked just fine.
Everything after that, did not
test test test test
^^^ yup, there it is.
- Where you see 'sea green', I was able to click on the color option and it placed the appropriate brackets and labeled it sea green but look at the 'test test test'. That's what it was doing earlier.
- Additional note: When I edit this to fix it, I can do ONE color code and then every subsequent attempt results in that rgb xx, xx, xx code. :scratchhe
test test test test
