Front door speaker depth (bose system)
Old Jun 20, 2011 | 09:35 PM
mightymaxgst's Avatar
I'm working on building a 2 way component set using an 8" woofer. I just wanted to know if anyone knows what the speaker depth of the front door speakers was. I need to know this so I can choose a speaker and start designing a crossover network for it. I have taken the door apart already to see why the driver side woofer keeps cutting in and out and came to the conclusion that the amp in that door was bad. So if i'm going into the door again I'm ripping everything out and redoing the entire speaker set, so I'm just trying to avoid going back in there.
Old Jun 21, 2011 | 12:10 AM
Tamas's Avatar
Registered Lunatic
It's in the very first post of this sticky thread.
Old Jun 21, 2011 | 07:12 AM
firebirdude's Avatar
User and Abuser
No regular 8" is going to fit in there. And most shallow mount sub designs are not available in the 8" size. I believe Kicker makes one (compVT line). Might have to build in a 1/2" thick mounting ring.
Second, are you looking to put a sub there? Or just a woofer? Most subwoofers are not designed to play anything above about ~300Hz. So please don't think you're just going to add a tweeter to an 8" and be good to go.
Old Jun 21, 2011 | 09:28 AM
Umm yes sir! Actually there are quite a few woofers that can go above 300hz, I'm pretty experienced at building 2 way systems. Hence the reason I'm building the crossover network. Building a speaker setup to accomplish what I'm trying to do isn't a problem, figuring out what can fit without taking my car apart is, though.
Old Jun 21, 2011 | 09:30 AM
Btw I have found quite a few 8" speakers that are 3.5" in depth or less...
Old Jun 21, 2011 | 09:34 AM
User and Abuser
Actually I said "sub" and "subwoofer". That is exactly why I asked you to specify if you were using an 8" subwoofer or 8" woofer. People often use the terms interchangeably. So I stand by my statement.
rotarywanker
Dec 8, 2022 05:56 PM
BigKid
Gulf For Sale/Wanted
Aug 13, 2015 12:40 PM
CMRine04
Jul 27, 2015 09:46 PM
Majictoast
Jul 18, 2015 06:45 PM
