No sound from Aftermarket Headunit
Old Jun 20, 2011 | 07:15 PM
DMannMazda's Avatar
I just put a pioneer 2300 double din in my 2004 rx8 and i have no sound out of the factory speakers, i used the metra kit and everything seems to be connected right. i think it has something to do with the factory amp because when i hook a speaker sraight up to the radio it works. ?? any help would be VERY appreciated.
Old Jun 20, 2011 | 07:19 PM
DubbsLuvs8s's Avatar
Identical problem, also with a Pioneer HU. I've narrowed it down to the Bose Amp in the trunk and I have a question out to Bose to see if it's because the remote wire doesn't have enough potential to click it on...unless other people have ideas. Hopefully we're having the same problem and it's an easy fix.
Old Jun 20, 2011 | 07:31 PM
firebirdude's Avatar
User and Abuser
Tons of other folks have used the Metra kit with the Bose system. So I doubt that's the problem. You sure you have it connected correctly? You might even try just putting 12V directly at the Bose amp input.
Old Jun 21, 2011 | 06:39 AM
RX8Geek's Avatar
Has anyone ever measured the current draw of the Bose amp turn-on lead? It could be that the newer Pio's can't put out enough current. A relay would probably solve the problem......
Old Jun 21, 2011 | 06:56 AM
User and Abuser
Plenty of people on here using newer Pioneer's too....practically all they're using actually....
Old Jun 21, 2011 | 08:40 AM
DMannMazda's Avatar
I figured out my problem. when i wired the radio i left the remote wire unconected since i wasnt using a aftermarket amp. so what i did was look through the metra instructions and there was a wire called amp turn on so i wired it to the remote and it works perfectly. stupid mistake on my part
Old Jun 21, 2011 | 09:32 AM
User and Abuser
I'd say.
Glad you got it figured out...
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Racingjunkie
Sep 29, 2015 05:05 PM
