When does AC turn on?
Old Jun 9, 2011 | 05:36 AM
Lavious's Avatar
Question When does AC turn on?
In my 2005 Shinka I have an interesting issue. When starting the car the AC is sometimes on, and sometimes not. I have tried without success to find any reasoning behind what causes it to come on. It seems to be completely independent of outside temp and/or HVAC control settings. Up here in oregon I rarely ever need the AC, so its easy to notice when it decides to turn itself on that I did not leave it on by accident.
I did have the issue with the HVAC control **** sending erroneous temp values, but that was fixed by the dealership(warranty) and I haven't had any issues with that **** since.
Has anyone else had this problem?
Old Jun 9, 2011 | 09:19 AM
firebirdude's Avatar
User and Abuser
Do you have automatic climate controls or something?
Pardon me asking, but if the manual fan speed **** is set to 0, the A/C never blows. Plain and simple.
Old Jun 9, 2011 | 11:33 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Ha ha! This is interesting. The op might have a automatic climate control device and don't even know how to operate it, lol
Old Jun 10, 2011 | 10:37 AM
Lavious's Avatar
When it's 40 degrees outside and the AC turns on..something is a bit wrong.
Old Jun 10, 2011 | 11:02 AM
Spin9k's Avatar
Momentum Keeps Me Going
AC f(x) is active when fan **** is above '0' and:
- AC button 'on' (light)
or even wo/that
- air flow direction is to floor (AC indicator does not light)
Old Jun 10, 2011 | 02:59 PM
User and Abuser
Please don't tell me you have the non-recirculate button (vent) button on...
Also, a small amount of air still flows through without the A/C being on and in recirc. The temp dial even works on this tiny amount of air. But we're talking a very small amount. Like 1/8th the amount of air that the A/C pushes with the fan on 1. Maybe this is what you're talking about? Every car does this...
But the A/C just doesn't turn itself on. It's not a house.
Old Jun 11, 2011 | 05:07 AM
Lavious's Avatar
*sigh* ...the problem is this...
I turn on the car and one of two things happens:
( fan setting of '1', temp on fully cold, intake on vent..this does not change)
A) the AC light stays off and I go on my merry way.
B) the AC light comes on and the air is noticeably colder...I wonder for a second if anyone else has this happen....I turn the AC off...and go on my merry way.
Old Jun 11, 2011 | 11:27 AM
jrx13's Avatar
Sounds like your temp control assembly. When you have the blower on anything other than off, and you turn your temp **** all the way to max cold, the a/c button comes on automatically. I think your "detent" is worn, so sometimes it thinks you moved it to that position? Either that on your a/c button is sticking.
In any of those problems, a new control assembly sounds like your fix. Thought they sold reman ones but I guess not.
http://www.finishlineperformance.com...cat=298&page=1
*edit* some have found ways to fix it:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
D13
Oct 1, 2015 07:55 AM
Racingjunkie
Sep 29, 2015 05:05 PM
