Just lowered -In need of an alignment for AutoX
Old Jun 6, 2011 | 03:10 PM
SayNoToPistons's Avatar
Wheels, not rims!!
I just had my RX8 lowered with Progress Tech springs (-1.2" & 205 Lbs./In Front, -0.8" & 145Lbs./In Rear) and still temporarily on stock shocks and sways. Tires are Kumho Ecsta XS' . I still need to get an alignment, but i am not sure what specs I should go for. I do not have to put daily driving, rain, or winter into consideration for my RX8 (hence the reason I will not look into stock alignment specs), but I will be going to my first Autocross session this month. I also plan on going to a few more other AutoX sessions and one track day at Lime Rock this summer.
If you guys can give me a foundation alignment spec to base future post track time fine tuning off of, that would be greatly appreciated. I will be going for my much needed alignment within a few days from now.
Old Jun 6, 2011 | 03:39 PM
HockeyRX-8's Avatar
TNC
just go -2 camber all around lol
Old Jun 6, 2011 | 09:03 PM
c0ldf1ame's Avatar
it kind of depends on your tires too but im using
-2 front, 0 toe
-1.7 rear, slight toe in
my car is a daily that sees track duty a couple of times a year, so far its been pretty good
reason for having less rear camber is it makes the rear slightly more loose, you may want to have even camber all round as a baseline
Old Jun 6, 2011 | 10:33 PM
sebarx8's Avatar
seebass
From: bloomfield nj now in miami ahhhh back in jersey now jajajjaja
Just lowered -In need of an alignment...in the same boat here bro
Old Jun 7, 2011 | 12:49 AM
Wheels, not rims!!
I was giving a guess of around -1.5 camber front with 0 toe, -1 camber rear with stock spec toe in.
Old Jun 7, 2011 | 12:56 AM
MagnusRacing's Avatar
Heck... it depends on many factors such as what tire you're running and if it's just an autocross car. If it was a dedicated autocross car running on fat Hoosiers I'd run at least 3 degrees negative up front (if you can get that much without offset bushings) and about 2.5 in the rear. And a little bit toe out in the front to help turn in.
Old Jun 7, 2011 | 01:29 AM
Wheels, not rims!!
As stated in the first post, I am running Kumho Ecsta XS' (extreme summers). I have no intention of running anything else yet. This is my weekend car and rarely do I use it for commutes, and when it do, the weather is always dry. I am going to Autocross my RX-8 this season for the first time. I am not Autocrossing with competition in mind, but more for seat time and getting the most out of my RX-8 with my set up. Hence the reason I would like to have a more aggressive alignment as opposed to stock (which still has me wondering for the estimated numbers), and as I learn the car, I can build upon the alignment settings and suspension upgrades in addition to my Progress Tech springs.
Jst4fun
Apr 17, 2021 07:43 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
duworm
Oct 1, 2015 04:57 PM
