New amp sub install.
Old Feb 26, 2004 | 06:44 PM
mlino01's Avatar
Just installed a JL amp and sub. I have it wired to the left right rear speakers as the amp has both hi and lo input. The sub sounds great but I was wondering if it would be better to wire it to the HU at the line level pins on the rear of the HU. If I were to do this would these leads go to hi or lo input on my amp.
Old Feb 26, 2004 | 06:55 PM
mlino01's Avatar
The rest of the components
Dynamat in trunk.
Old Feb 26, 2004 | 07:00 PM
mlino01's Avatar
CV tweeta ina panel
These Cerwin Vega large tweeters sound awesome.
Old Feb 26, 2004 | 07:14 PM
mlino01's Avatar
Rear deck and door speakers
The reason I went with these speakers is they sound great at low volumes and really handle the stock decks power output when cranked up. they have exellent sound presence front to back and I run the fader at 0. I was leery of runing mixed speaker components and am glad I went whith a matched set front to back. The remote on the JL amp is really handy to adjust bass out put for different types of tunes.
Old Feb 26, 2004 | 07:30 PM
mikeb's Avatar
100% Italian
nice install
what size and type is that jl sub
Old Feb 26, 2004 | 09:08 PM
mlino01's Avatar
It's a pro wedge 10 w3v2
Old Feb 26, 2004 | 10:55 PM
nate109's Avatar
Nice setup. I think your sound would only be slightly better if you wired it from the HU, but you'd still need to use the high-voltage input to your amp. It looks like you have the standard (non-Bose) system, and I don't think there's a way to get a true preamp signal. If you're already happy with the way it sounds, keep it how you have it, it won't be worth the trouble to re-wire it.
Old Feb 26, 2004 | 10:58 PM
mlino01's Avatar
Thanks that what I thought.
Old Feb 27, 2004 | 12:05 AM
stauburn's Avatar
Hey there where did you get your set up done and for how much??
How many watts do you have going?
I live in Elk Grove too
Old Feb 27, 2004 | 01:58 AM
mlino01's Avatar
I installed it myself myself. One of the hardest parts was dynamating the entire trunk As for wattage I'm running the stock deck and the sub is powered by a JL at 120 constant , 250 peak. power I know that sounds lite but that single 10 booms. I think the JL pro wedge enclosure has something to do with it. If you want to check out my install your more than welcome. I live in the Laguna area. I'll shoot you a PM
Old Feb 27, 2004 | 01:22 PM
mikeb's Avatar
100% Italian
I need to do the dynomatt install NOW
I have been avoiding it becuase it is a royal pain
Old Feb 27, 2004 | 07:34 PM
mlino01's Avatar
Yea I did the whole trunk including the trunk lid and it took 3.5 hours. My back hurts just thinking about that install.
Old Feb 27, 2004 | 10:11 PM
BlueThunder's Avatar
Whats the dynamat for?
Old Feb 27, 2004 | 10:44 PM
mxmedina's Avatar
My kenwood 10" sub & Kenwood 600Watt
Here is my set-up that is similar to your set-up except that my amp is in the rear of the sub box, hidden but can be reach via the rear arm rest section. This one hit s nice and hard and works well with the original radio.
Old Feb 28, 2004 | 03:21 AM
mlino01's Avatar
Nice Kenwood setup. What did you use to keep the sub in place. I used industrial 2 inch sticky back Velcro on both the sub and amp and that stuff works real good. I had to take out the sub to do the Dynamat and it took quite a bit of effort to unfasten the the velcro.
Old Feb 28, 2004 | 03:28 AM
mlino01's Avatar
Dynamat is a thin rubber adhesive mat that insulates the trunk minimizes the rattling, keeps the bass tighter and gives your bass a slight DB boost in the car.
Old Mar 4, 2004 | 01:03 PM
adrian-1's Avatar
Ex- member.
Re: Rear deck and door speakers
Where did you place the remote bass ****? I've ordered one and I was hoping it'll fit next to the cigarette lighter.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
just1jack
Sep 9, 2015 04:45 PM
