SR Cold Air Intake
Old Feb 25, 2004 | 09:25 PM
RXhusker's Avatar
Int-X 293WHP 242TQ :)
SR Cold Air Intake
Surprised nobody has posted this yet -- a true cold air intake for the 8. Price doesn't seem unreasonable. I'm going to try and get more info. And they say it is quiet -- I can't decide if that is good or bad :D
SR Cold Air Intake
Old Feb 25, 2004 | 10:07 PM
M-ster's Avatar
hmm.. only 1 picture, I wonder how the rest of the intake looks like?
Old Feb 25, 2004 | 10:18 PM
Speed Racer's Avatar
Certified track junky!!!
I also think that $449 is a little steep for an intake.
Old Feb 25, 2004 | 10:42 PM
RXhusker's Avatar
With the two short arms at $200 to $260 -- I am not surprised that a true cold air system is a couple bills higher. Need to get more pics and install info. to truely judge. Looks somewhat promising. I have to remove the front bumper anyway to install the MS nose -- might have to put in a cold air intake also :D
Old Feb 25, 2004 | 10:54 PM
wakeech's Avatar
mostly harmless
hahaha, omfg... read the description:
From SR Motorsports website
This powder coated CNC built 6061 billet aluminum and polished 304 stainless steel kit replaces the stock restrictive plastic RX-8 intake box. Our intake system is a true Ram-Air Cold Air Intake, receiving air only from outside of the super heated engine compartment. (Most intake systems are just a cone filter and pipe which grab hot air from around the radiator and the engine , which is why they don't have the same good horsepower increase that our kit does.) Our system is quiet too! No loud funky intake noise.
puh-lease. if this was not just designed for the ricer, it was at least described as it would be by one.
Old Feb 25, 2004 | 11:31 PM
rotarygod's Avatar
That's called good advertising. It sells product and that is the number 1 priority of any business. Some won't believe it but many will. What should it have said; "Here's ours!"?
Old Feb 25, 2004 | 11:36 PM
wakeech's Avatar
mostly harmless
i'm not saying it isn't, but for god's sakes, they could say more than just buzzwords (CNC, ram-air *ha ha*, 304, billet, etc).
...and i suppose what my point is, is that this isn't being targetted at real enthusiasts, which then brings to my mind it's actual performance benefit.
Old Feb 26, 2004 | 12:24 AM
bureau13's Avatar
You're kidding, right? What self-respecting "ricer" would buy an intake that brags about being (*gasp*) quiet???
jds
Old Feb 26, 2004 | 12:42 AM
rotarygod's Avatar
lol that's true!
Old Feb 26, 2004 | 01:47 AM
Rotary Extreme's Avatar
A simple ram air intake will not work on the RX8 due to the use of MAF sensor instead of MAP sensor. If there is any ramming air, it's going to create too much turbulence and throw off the MAF sensor reading. Also when crusiing at high speed, the air that goes passing the MAF will bounce back out. You can expect a CEL right away the first time you drive it on the freeway.
A ram air intake will work only if it has a variable ram air duct that opens according to rpm, throttle position, and load. We were the first company trying to make a ram air intake and then found out in order to make a true ram air intake, it will cost at least $1000 for each one with all the electronic and butterfly valve needed. It's simply not worth it for the additonal 2-3 HP.
The factory air duct was designed to avoid direct ramming of the intake air. The primary air duct is pointing side way and the secondary air duct has a shield blocking in front of it.
So if the SR intake does have the air filter positioned at the front of the mouth, it's not going to work on a street car. You can use it for 1/4 mile when the throttle is always open.
If the filter is inside that black tube, it's just a cold air intake and it looks like it's more restrictive than stock. It can't be described as ram air intake because there is no ramming effect.
Chuck Huang
Old Feb 26, 2004 | 07:16 AM
XeRo's Avatar
Normality is Obscene
Good call...i seriously doubt they put the necessary electronics in their "Ram-Air" intake...and selling it for $450...unless they used some R/C parts ....lol...
Old Feb 26, 2004 | 05:53 PM
wakeech's Avatar
mostly harmless
aaaaaanyways, for more information on "ram" air, see posts here:
https://www.rx8club.com/showthread.p...threadid=18698
it's marketting bs.
Old Feb 26, 2004 | 08:10 PM
You don't replace it with a new one. You reuse the stock one.
Chuck Huang
Originally posted by God of Thunder
Is it not necessary to replace MAF on your intake?
WranglerFan
Aug 21, 2022 01:29 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
RXFEVER
Sep 11, 2016 02:51 PM
