CS: softer front sway bar?
Old May 13, 2011 | 10:47 PM
dmitrik4's Avatar
please wait for the beep
One thing I've noticed is that my car still has some steady-state understeer. Alignment and tire pressures help, but haven't dialed it out completely. Rather than looking for ways to loosen up the rear end, I'm wondering about ways to increase front grip.
Has anyone tried running a softer front sway bar? The stock bar is 26.5mm. The old auto-tranny bar is 25.4; the stock MX-5 bar is 21.1. I know that going to a softer front bar would give up some crispness in transition, but should provide benefits in sweepers.
Old May 14, 2011 | 01:26 AM
lol, not again ....
Old May 14, 2011 | 08:37 AM
Spin9k's Avatar
Momentum Keeps Me Going
Under what conditions and speed ie, doing race track, street, or autocross driving are you getting "steady state understeer"? Any time anti-sway bars are under deflection, by defintion, you are in a transient condition.
I've seen cars that appear to lack anti-sway bars on a race track. They are quite comical in appearance from behind.
Old May 14, 2011 | 10:49 AM
tpdrx8's Avatar
He says CS so I am assuming autocross, but spins on the right track, what is your setup now? tires? alignment? pressures?
I run the baghead bar on it's softest setting which I have been told is a tad stiffer than the stock bar.
The ONLY time I have had my car push is when the dial bewteen my ears is set wrong.
Old May 14, 2011 | 08:07 PM
EricMeyer's Avatar
Not sure if your looking for alternative approaches to problem solving but I'll throw in my .02 You have what appears to be a pretty good notion of other swaybar sizes and this makes me think your alignment and pressure changes are educated and correct. If this is the case I would share that SOME people think reducing grip in the rear end to allow for more grip in the front is a bad thing. Some people think that there is a fixed amount of grip in the rear and reducing it will make the rear loose, have less grip and work less than optimal. In reality you may have TOO much rear grip and you NEED to get that too the front. Sharing some setup info (as others have hinted at) would help us to help you.
My gut says (and I'm probably wrong) it's either a ride height issue in the rear, too low of spring in the rear or too high spring in the front. I'm going with either of the first two. Final answer. Don't need to phone a friend.
Share more. There are a strong handful of smart people on this forum that enjoy helping people and are experienced enough to do so.
Old May 14, 2011 | 10:05 PM
dmitrik4's Avatar
Thanks Eric. I'm autoXing in C Stock, so my changes are limited to shocks, tires, front bar and alignment. no spring rate or ride height changes. no rear bar changes. I've been doing this on and off for about 10 years, but seriously for ~3 years. I'm a mechanical engineer with a decent understanding of car setup, but i'm by no means an expert.
shocks: OTS Koni Sports. Almost (i.e., 1/4 turn off) full stiff in the rear; ~2/3 stiff in front, depending on the course (we use both a transition-heavy runway course and a sweeper-heavy parking lot). Tires: 285/30/18 A6s on required stock-size wheels. Pressures are typically ~34f/36r, but might change depending on how the car is working. Front bar is stock.
Alignment:
Front
Camber: max negative, which on my car is ~-1.2*
Caster: +6.5*
Toe: 1/16" out per side
Rear
Camber: -1*
Spin - i'm not sure i follow. "Transition" in the sense I would use it is moving from one state (e.g., straight-line driving or constant speed) to another (e.g., turning or accelerating). Steady-state would be maintaining whatever attitude the car is in (e.g., in the middle of a sweeper). A good example of steady-state cornering is a skidpad; while the bar is in torsion at that point, the car is in a steady state (i.e., constant cornering load, constant speed - rare as that might be during an autoX run).
Originally Posted by TeamRX8
lol, not again ....
wow, thanks Mark.
Application is autocross and he is only allowed to change the front swaybar, shocks, and alignment with any size DOT-R tire on the factory width/diameter wheel. You simply need to optimize the alignment and shocks to get the car neutral. You can even use these same changes to get it loose enough to justify a stiffer front bar. Making the setup softer is going in the wrong direction. It's been tried and nobody has been successful with it. OE or stiffer has always been the ticket. Don't thank me, thank the people who already tried to pioneer it. Rear toe out is not necessary either.
Old May 14, 2011 | 10:13 PM
40w8's Avatar
My 07 GT had that heavy understeer from day one. My goals are to always fix or tune with what I already bought. The alignment specs show that the front wheels should have about 1 more deg of camber than the front, so if you just send it to the shop, the rears will look splayed (some ricers like that look). Get that rear camber turned down to about -1.65 (the minimum I could get), and you can thank me later.
dmitrik4's Avatar
the minimum i could get in the rear was ~-1*, which is what i have. the max i could get in the front was ~-1.2*, which is also what i have. the shop i use is run by guys who have been autoXing and club racing for a long time.
and that was my question...have other people tried it, and what were their experiences? you know, you could have written this post first.
Old May 14, 2011 | 10:41 PM
You could search first too as I only know what other people have posted here and seen their results. Hence my orinal post so go stand in front of the mirror and roll your eyes there instead
Old May 14, 2011 | 10:57 PM
40w8's Avatar
I just saw your tire size and pressures, and while I track not AutoX, isn't that a killer large tire for the stock wheel/
I'd think 265/35r18 would be plenty overkill, and I'd run 3 or 4 more psi hot in the front over the back.
Old May 14, 2011 | 11:05 PM
dmitrik4's Avatar
a 265/35 is significantly taller than the 285, which works fine on the wheel but does not endear me to my tire guy. plus Hoosier doesn't make a 265/35/18 A6.
i did search; the hugely powerful vBulletin search tool showed me one post from 2008 where someone liked a smaller bar. otherwise everything i found discussed using either the stock bar or a larger bar.
if you can point me to some other discussion, i'd appreciate it. otherwise....
Old May 15, 2011 | 12:26 AM
40w8's Avatar
Yeah, I like to gear down, too, especially since I have a geared up 6spd auto.
I run 225/40r18 Hankooks v12's which are significantly stickier and 2#'s lighter than the original 225/45r18 kumho SPT's.
Just for giggles and even lighter, I'm gonna run 215/40r18 Hankook v12's next, and I'll have 40# wheel-tire combo.
Old May 15, 2011 | 05:15 AM
bse50's Avatar
#50
Tyres are the culprit. They're just too wide and mounted on narrow rims that's even worse.
With the limited amount of modifications that you're allowed to perform grip shouldn't be a problem. You will probably decrease your "lap"times by working on faster transitioning times and steering response.
Old May 15, 2011 | 06:09 AM
lol, not again ....
yeah, here we go ....
Old May 15, 2011 | 07:46 AM
Spin9k's Avatar
Spin - i'm not sure i follow. ... A good example of steady-state cornering is a skidpad;
That is a good example, and perhaps many corners in autoX simulate that, at least in the short term, where continuous understeer slows you considerably when your setup isn't right. Wasn't sure what you did with the car... anyway nothing I can tell you as I'm not an autoXer. Others have the experience to help and advise as to setup ... except I can assure you the fun is in eventually getting it 'just right' and enjoying the results
Old May 15, 2011 | 09:41 AM
tpdrx8's Avatar
Tyres are not the culprit.
I have been running the 285's on 8" wheels for over a year. Based on the success that we are having with them - first and second place at the Atlanta Tour for example - I would look elsewhere.
I can tell you that you have your pressures backwards to what I have been running - I run 39F and 36R. Fossum/Ruggles do something more like you have so that's not all of it, but it would be a simple place to start and see if it makes a difference for you and your car.
Old May 15, 2011 | 10:26 AM
bse50's Avatar
#50
There's who's winning with 255 wide tyres so stating results is not the way to determine the setup. His "problems" are.
Heavy understeer means too much rear grip 99% of the times. With 285 tyres that's what your getting with such an underpowered car. Pressures may help but the best way to take understeer off, given that the alignment and suspension setup are spot-on, is to work with tyre sizes.
The benefits of narrower tyres go beyond that but this is not the place to discuss such matters. Sure running around cones in parking lots is different than tracking the car but the point is still sound imho.
Old May 15, 2011 | 01:19 PM
dmitrik4's Avatar
i've been thinking of bumping down to 245s or 255s, but don't expect it to change the balance of the car...after all, if moving down in tire width reduces rear grip, it should reduce front grip as well. and i don't believe i said anything about "heavy" understeer; it's a little pushy mid-corner and i'm thinking about how to improve that.
in Stock classes, wider tires almost always prove to be faster, even if they are "too wide" for the wheels.
i'm going to start trying a much wider range of pressures to see if i can start to zero in on something that works for my car.
Old May 15, 2011 | 01:38 PM
bse50's Avatar
#50
With an RWD car the problem is that the front wheels just act as a "resistance" when turning, if you have too much rear grip you will just keep "pushing" the front out of the desired turn radius.
It surely is worth a try, just find somebody with a set of stockers and you're good to go.
Old May 15, 2011 | 01:46 PM
Come to the USA and show us how to do it then because we obviously don't know how even though that concept has also been shown not to prove out for the intended application
You are easily short at least 1/2 deg camber on the front, it is there legally for the taking ...
Old May 15, 2011 | 01:50 PM
bse50's Avatar
#50
i wish i could, i had to do something pretty similar because of a couple of tight chicanes where my previous setup was prone to understeering.
Old May 15, 2011 | 02:42 PM
dmitrik4's Avatar
that's one thing that has been bugging me. time to start loosening bolts and pulling on things, i guess. that and pressures might get 'er done.
no need to go that far; i do drive the car on the street every day.
FWIW, it seems to push a bit more on my stock-size street tires.
Old May 15, 2011 | 02:51 PM
kbrewmr2's Avatar
pull a "hoppe" and start bending things in favorable directions
if you're short on what camber vs what other people can get that seems like spot #1 to work on to me...
Old May 15, 2011 | 03:24 PM
dmitrik4's Avatar
my guy suggested just that, but i think i'll try staying legal.
