Lilliput 629 screen adjustments
Old May 3, 2011 | 12:02 AM
Rotaman's Avatar
NZ Lilliput 629 screen adjustments
Hi There
I was wondering if someone who has installed a Lilliput 629 screen can let me know the exact changes I have to do to the setup to get the screen to turn on when it senses power to it.
So I don't have to use the on/off button to get it to go.
I know how to get into the settings, just need to know what I should change.
Thanks, any help will be much appreciated.
Regards
Rotaman
Old May 3, 2011 | 09:03 AM
firebirdude's Avatar
User and Abuser
Probably have much better luck over at mp3car.com
Old May 3, 2011 | 11:00 AM
NgoRX8's Avatar
when on and working in VGA (image on screen), push 588988 on the lilliput controller. It should bring up a menu. Press the menu button twice till you see a line that says 'car power state.' The number corresponding to it should be switched to 2.
Old May 3, 2011 | 02:54 PM
Rotaman's Avatar
Thanks for that info, I didn't realise you could change the setup menu using the remote. Also if you hold down the power button on the screen for a length of time, it will bring up the setup menu as well, and then you can change setup menu screens using the menu botton, and change settings using the arrow keys.
Old May 3, 2011 | 08:15 PM
sebarx8's Avatar
seebass
From: bloomfield nj now in miami ahhhh back in jersey now jajajjaja
which one do you have??? of the Lilliput 629
Old May 4, 2011 | 05:39 AM
Rotaman's Avatar
The screen I have is the 629GL-70NP and on the box the letter T is marked.
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
ShellDude
Oct 1, 2015 09:55 PM
Learners_Permit
Sep 27, 2015 07:38 PM
