FYI: stock RX8 wheel weight, size & offset here !!
Old Feb 23, 2004 | 09:30 AM
AF-RX8's Avatar
This message is for anyone who is looking for the weight, size and offest of the stock OEM RX8 18" wheel
Size 18 x 8
Offset 50
Weight 47.5 to 48.5 lbs and that is with a bridgestone RE040 225/45/18 tire weighed on a pretty accurate digital bathroom scale
It's not bad considering the size and I bet the wheel itself isn't THAT heavy but I know the bridgestone tire is on the heavy side.
I hope this helps out anyone looking for this information !!!
Old Feb 23, 2004 | 11:54 AM
HottRodder's Avatar
Just to make this thread more complete.
Center Bore = 70mm
Spacing = 5 x 4.5" (114.3cm)
Old Feb 23, 2004 | 01:18 PM
santino's Avatar
don't forget to add the weight of the tire pressure monitors...and the wheels weights to balance those! a good amount of the weight that you calculated stem from the balances and the TPMS.
santino
Old Feb 23, 2004 | 02:47 PM
Pk14's Avatar
Canzoomer measured the stock wheels at 21 lbs each.
Pk
Old Feb 23, 2004 | 05:01 PM
310Guy's Avatar
4AT poor mileage king
I think that was just for the rim, not with tires...
Old Feb 23, 2004 | 05:20 PM
AF-RX8's Avatar
That definitely was just the rim which makes sense because the Bridgestone website shows the 225/45/18 RE040 weighing 26 lbs, then add the few ounces of weight from the wheel weights and the tire pressure sensor and your right around the 47.5 to 48.5 lbs I got this morning when I weighed the wheels and tires
Old Feb 26, 2004 | 01:17 AM
yves's Avatar
How much do the 16" wheels weigh that come standard on the automatic transmission model? And what do they look like? Anyone have a photo of them?
Old Feb 26, 2004 | 01:53 AM
IKnowNot'ing's Avatar
Re: FYI: stock RX8 wheel weight, size & offset here !!
Originally posted by AF-RX8
Offset 50
Dear AF-RX8, I guess units are mm.
Thanks guys for wheeldetails. Will come handy to source some 17" winter wheels...
Cheers
Old Feb 26, 2004 | 02:45 PM
Gord96BRG's Avatar
Re: Re: FYI: stock RX8 wheel weight, size & offset here !!
Also, be sure to search on "winter tires" or "winter wheels" - there are many, many threads discussing the options for 17" wheels and tires, and many of us have purchased winter wheels in the past few months.
Regards,
Gordon
Old Sep 21, 2015 | 02:22 AM
desertmazdas's Avatar
AZ lowest wheel size and offset on rx8
anyone know what the lowest wheel size and offset that fits on rx8,and any good sites that sale wheels for the low
Old Sep 21, 2015 | 08:36 AM
SayNoToPistons's Avatar
Wheels, not rims!!
19x15 -20 with 215 width tires.
www.swaggedstancehella.com
Old Sep 21, 2015 | 12:36 PM
NotAPreppie's Avatar
What am I doing here?
Holy thread necromancy, Batman!
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
GK1707
Aug 3, 2015 10:23 PM
RX7.9
Jul 20, 2015 12:01 PM
