Unorthodox subwoofer instillation
Old Apr 12, 2011 | 10:14 PM
xXCataclysm13Xx's Avatar
I have an odd question. I plan on installing 2 12 kickers but at the moment he money isn't there but I do happen to have a paradigm 10 home audio subwoofer and I'm looking for a quick way to install it to hold me over uniill I get real subs. Would this be possible?
Old Apr 12, 2011 | 10:27 PM
rickeo's Avatar
running on double cream!
Save your money. Do it once, do it right.
Old Apr 12, 2011 | 10:35 PM
Well I've got the sub already. I wouldwnt rly be spending any money. It has an internal amp already. If I just spend a few bucks on instillatio I won't rly care. I'm addicted to bass and I'm looking for more of it. Lots. just gna take a while before I cn get my real subs. Most likely in august
Old Apr 12, 2011 | 10:50 PM
Tomago's Avatar
808/1000
The money converting it from AC DC alone isn't worth it. Save your money and just wait until August.
Old Apr 12, 2011 | 10:52 PM
azzuro's Avatar
So this Rotary thing...?
We're gonna need more details on your sub to advise one way or the other. Also, do you have an aftermarket deck? The stock one can be a real pain.
Old Apr 12, 2011 | 11:26 PM
It's all stock but I've got big plans for my baby. I guess I'm just going to wait till august seeing as it might be more of a pain than I realized. If anyone knows a good solution I'll take it but if not.. Haha august can't come soon enough. But I have always wondered, will subs affect the 8s perfect balance enough to make a difference or not?
Old Apr 13, 2011 | 12:45 AM
Kusanagi's Avatar
Don't do that, a bass driver designed for home audio is not built to withstand the heat in the trunk, glue/rubber surround will perish pretty quickly and give way.
Depends on the design of the driver, most home audio has shorter voice coil because they rely on the large chamber/ported box to create the frequency/db required, hence less stroke on the cone, on the other hand car woofer has longer stroke, as car has less space for box, thus they require more stroke and cone movement to create the same frequency/db, there are many other things to consider as well, so I would suggest to save up and get the right drivers.
edit: I re-read your question, and realised you're going to just put in the entire home theater sub-box in the trunk? I would highly against it.
Old Apr 13, 2011 | 03:22 AM
hoss -05's Avatar
Lucky #33
This sounds like a Really bad idea.
Old Apr 13, 2011 | 06:45 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
where are you located? i have a pair of kicker 12s in a bandpass box that is just taking up space in my garage. the box wont fit in the trunk without being moddifed but ill sell ya the set up cheap if your local
Old Apr 13, 2011 | 07:59 AM
LunchboxCritter's Avatar
Disco Biscuit
You can go Ghetto if you want, after all we are in America. Here's what you'll need.
$26.00 for a dc/ac power inverter. http://www.walmart.com/ip/Tripp-Lite...let/3910265#rr
$19.88 lineout converter http://www.walmart.com/ip/Scosche-Ad...ts/10756155#rr
I would recommend the few extra bucks and get this line converter instead. $23.45 http://cgi.ebay.com/Stinger-Adjustab...item3f05b54904
Old Apr 13, 2011 | 10:27 AM
hoss -05's Avatar
Lucky #33
FYI I have seen many AC/DC inverters die in flames, I would not put a cheep one in my car. Cheep ones are also all square sign wave and sometimes home electronics have a very hard time with that.
Ill say it again, this is a very bad idea.
Old Apr 13, 2011 | 01:01 PM
firebirdude's Avatar
User and Abuser
hahahaha ooohhhh to be 16 again...
Old Apr 15, 2011 | 07:13 AM
AJRx892's Avatar
I mounted my whole home surround sound system in my car I just drilled holes in the pillars and screwed them in and covered it with duct tape kind of like they do at concerts it sounds amazing! Little bit of distortion though but I wired them correctly I think sometimes there's a slight burning smell but I think that possibly could be the clutch?
Old Apr 15, 2011 | 08:08 AM
User and Abuser
pics!
Old Apr 15, 2011 | 08:41 AM
Disco Biscuit
^+1 pics!!!
Old Apr 15, 2011 | 08:01 PM
200mph I'm in Oklahoma. How much do u want for the subs and what kind of kickers are they? I'll see if we Cnt make a deal.
Old Apr 15, 2011 | 08:02 PM
And yea lol it prob was a bad idea but I'm legitamly addicted to bass lol so what ever it takes. I'm just going to wait until I can get my subs.
Old Apr 15, 2011 | 08:54 PM
azzuro's Avatar
If your home theater sub didn't have the amp built-in, it'd be so much easier. Since it looks like it does, I think you're more or less stuck.
Old Apr 15, 2011 | 10:06 PM
Disco Biscuit
You can do as I mentioned above to install and use your home subwoofer.
Do you really think that if dc/ac power inverters caught on fire as frequently as has been stated that anyone would make them? What sort of liability would that create on the companies making them? I agree cheap one's are not as good as expensive ones, but on a limited budget they will work.
You simply jack the line converter into the wires going to your 6x9's in the rear dash, rca's from the converter to the amp in your home theater sub, and hook the ac plug from the sub into the power inverter and run the inverter through the access to the cigaretter lighter plug in the center console. Wallah you are bumping.
Don't be a pud, just do it. In order to use dude's subs you're going to need an amp, an amp wiring kit, and if the amp does not have a built in line converter then you are going to need one anyways.
If you are going to truely do it correctly then you need an aftermarket head unit and a mounting kit (the metra kit for the rx8 is $150.00 not including a head unit). Depending on the amperage draw on your electrical system from your amplifier, you are either going to kill your alternator, or you'll at least need a secondary battery.
When I was kid I had a ghetto system or two. One consisted of an Alpine 4 channel amplifier, 2-10's in a bandpass box, and had a portable cd player that I was using as a head unit. Believe it or not my car sounded better than alot of more fortunate people's cars.
It's your car so you can do whatever you want, but I think certain things are a certain right of passage as a young pup.
Old Apr 15, 2011 | 11:32 PM
laythor's Avatar
I zoom therefore I am.
quoted for truth
Old Apr 22, 2011 | 10:51 PM
Alright so since I lack a job and money I had to go kinda cheap. 2 12 Sony xplods a 760w pioneer and capacitor for 150 with a box the box just dosnt fit so I'ma sell it and get a custom box. But at least I now have subs.
Old Apr 22, 2011 | 11:18 PM
hoss -05's Avatar
Lucky #33
^---------------- good for you!
Old Apr 23, 2011 | 09:20 AM
Disco Biscuit
congrats
Old Apr 23, 2011 | 09:55 AM
User and Abuser
Quality product
Old Apr 23, 2011 | 10:26 AM
Tamas's Avatar
Registered Lunatic
^^ indeed.
I wish this would have been available at the time I did my setup... at this price, this is the best deal around.
Wouldn't have had to pay a small fortune for my system
