Engine cover grommets pulled out and 1 lost
Old Feb 15, 2004 | 09:26 AM
MikeS's Avatar
Be careful when you remove the engine cover. Apparently, the rubber grommets that hold the front of the cover pulled loose and I lost one completely. I didn't realize that I had only one securing it in the front. When I checked the oil yesterday and attempted to put the cover back on, it fit funny. I peered down into the engine compartment and retrieved one grommet at least. The other is probably on the beltway. I'll visit the dealer and get a couple spares now.
I may lightly lube the inside of the grommets with silicone so the cover pins don't grab the grommets so hard.
Anyone else had this happen?
Old Feb 15, 2004 | 09:28 AM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
There is a TSB on this and they will replace them under warranty.
Old Feb 15, 2004 | 11:34 AM
RX-8 friend's Avatar
They've changed the replacements so they don't fall out. You probably don't need spares.
Old Feb 15, 2004 | 01:27 PM
MikeS's Avatar
TSBs
Thanx. Where do you all find those TSBs? Are they posted online?
Old Feb 15, 2004 | 01:43 PM
adrian-1's Avatar
Ex- member.
http://www.finishlineperformance.com...ocs/index.html
Rosenthal dealership posts them.
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
ShadowDragon78
Aug 11, 2015 06:42 AM
Obivious
Jul 29, 2015 05:57 PM
