NW RX-8 Forum Serving WA, OR, ID, AK
Helllppp!!!!!
Old Dec 2, 2010 | 10:04 PM
user 621971230813's Avatar
Helllppp!!!!!
:bigeyes: My RX8 just did something that really scared me and I need to know how to fix it!
So earlier today it was misfiring or something around 5000rpms, the power would just drop like you were shifting or something and then pick back up but it shouldn't be doing that.
Then just now as I'm driving home coasting down a hill the engine decides to shut off, I started it back up but now there's a strange ticking sound coming from the engine that I don't remember being there before.
Did the engine just blow up? That's ok because it's still under warranty :nod: But if not then what is wrong with my baby?
Old Dec 2, 2010 | 10:06 PM
FoxeyL8y's Avatar
Derp Kitten
Stats on the car?
When did you last replace plugs, coils, wires?
Old Dec 2, 2010 | 10:13 PM
RX8Soldier's Avatar
Time for boost...
Is your cat still under warranty? Sounds like it;s toast
Old Dec 3, 2010 | 08:33 AM
It's a 2004 GT and all of the plugs coils and wires were replaced about 40k miles ago, but how would that cause the car to just shut off?? (I'm not extremely knowledgable about the car yet, just starting.)
Old Dec 3, 2010 | 09:34 AM
ANIBALRX8's Avatar
Cool
it wood not, I still have my original coil and wires in my car and it runs fine. I am on my second engine, my rx8 is an 04 gt and I felt a big power lose and check engine light come on and after that the car was fine . It did this to me twice, took it in and i got an new engine a week later around 43000 miles, am at 60000 mile and running strong now!!!
Old Dec 4, 2010 | 10:26 AM
So what exactly causes that power loss? The mazda dealer here is awful and when I take it in and say the engine is toast they won't believe me unless I have very specific details.
Old Dec 4, 2010 | 10:41 AM
ANIBALRX8's Avatar
millan mazda was great. I toll them that I felt a power lose went I went to past a car and the check engine came on, ten minutes later it went away and a week later it did the same thing but the check engine stay, so I park the car and the next day off monday I toke it in, I pick it up later that day, they toll me the order a new engine and to drive it easy and not hard for the week, the next monday I took it in and by Wed I got my car back!!!
Old Dec 6, 2010 | 03:20 PM
dondo's Avatar
100% baller (finally!)
what year, how many miles?
you need to take it in for a compression test. ask for the specifically and say it's down on power. make sure they give you the report afterwords and we can tell you what's up.
Old Dec 6, 2010 | 03:39 PM
Nemesis8's Avatar
Bigus Rotus
^ what dondo said. You need to specifically say, "I have no power" The compression test must be reported at a certain RPM also, for each rotor, if you get one. Could be cat, but shutting off me thinks it has given up it's ghost....
Old Dec 7, 2010 | 09:58 AM
Ugh unfortunately the engine is fine, had the compression test done and it thoroughly checked out, everything was in great shape except it needs new valves which of course are not covered by the warranty
Oh well, I still have a few months for the engine to blow
Oh and it's an '04 with 85k. It's in great shape except the stupid valves :P
Old Dec 7, 2010 | 11:10 AM
Nemesis8's Avatar
Bigus Rotus
The valves are cleanable.
RX8 Bulletins
SSV Bulletin
Old Dec 7, 2010 | 12:02 PM
dondo's Avatar
can you post the compression report?
Old Dec 8, 2010 | 10:31 AM
Dirty valves aren't the problem, they actually aren't working right. There was a service report put out for this issue by Mazda and I took a look at it, it's legit.
My records are in the car which is is the garage at the moment, but the general numbers were 8.9 with one or two 8.7 for the compression test
Old Dec 8, 2010 | 01:21 PM
dondo's Avatar
thats a strong motor
