SebtownRx8
11-18-2010, 10:22 PM
http://www.energysuspensionparts.com/proddetail.asp?prod=9.5166
Best way to see you bracket place you head on the ground directly next to your front wheel so you can look through the spokes, youll see you bar then the bracket, if it looks like my silver one its time for a change.
this one is for 32mm front aka aftermarket like progresstech or rb and such. you can find any size that you require, because its still the same 14mm nut that takes 3 mins to undo :)
Tools Required
14mm Open wrench (for if you broke you bracket like me and its bent so you can not get a socket around one side.)
14mm socket
1"-3" extension
torque wrench or a socket wrench (torque wrench is really just leverage and the fact you can preset it to the torque, but you always end up doing it tighter..)
lithium grease
flashlight (if you install at night like i did.)
Step1 locate your broken bracket
Step2 spray a shot of liquid wrench on the 2 nuts
Step3 remove the 2 nuts
Step4 remove old polyurathane bushing
Step5 grease bar, new bushing, and new bracket,
Step6 install make sure to tighten them down pretty tight.
Step7 take for a test drive. jerk the car left and right a few time and take around a few corners.
Step8 re check the nuts to ensure proper tighten after test drive.
Step9 every oil change spray some lithium grease on the bushings.
Its really easy to change out, no need to jack up the car i'm 6-3" 160lbs and can reach both the front and rear no problem. hope this helps any questions that arise during install.
Pics are what i was going through.... the zerk fitting is that little thing on the gold bracket that has a whole so you can grease gun them, o also the bushing has a whole so the grease penetrates to the bar rather than the bushing
Tools Required
14mm socket
1"-3" extension
lithium grease
