Supercharger
01-20-2003, 10:23 PM
The standard aluminum rotors in the Renesis engine can be replaced by lighter MMC units.
Check out www.mmccinc.com
View Full Version : Metal Matrix Composite Rotor Supercharger 01-20-2003, 10:23 PM The standard aluminum rotors in the Renesis engine can be replaced by lighter MMC units. Check out www.mmccinc.com Hercules 01-20-2003, 10:27 PM The rotors in the Renesis are pretty light as it is... I think lighter exhaust system, wheels, etc are better to replace as they won't be as key an element as the actual rotor themselves :) For me though... bone stock :) I figure in three years I'll be in the MPS RX-8 or something, so I'm not worried about the power too much :) maxcooper 01-21-2003, 05:27 AM MMC is used for brake rotors, but I am not aware of any Wankel engine rotors made from MMC yet. The stock Mazda rotors are iron, but so are brake rotors usually, so I guess it might work. And as Hercules said... the RENESIS rotors are pretty light already. -Max Supercharger 01-21-2003, 08:41 PM For those of you who have the budget to go racing, this is a good option. The next step is replacing the heavy cast iron front/intermediate/rear housings with MMC units. The MMC material I am refering to is: ceramic particles reinforced aluminum alloy. Hercules 01-21-2003, 08:48 PM While it might be a good deal, and good parts I am wary of upgrading my car in such a way that my warranty is voided.. cracking open the rotor housing would definately do that. There are cheaper mods that can be done and allow for an increase in horsepower as well. The real change would be for the rotors to get wider but that comes as a different engine, because you can't upgrade to wider rotors.. the housing won't accept it. This is rather a bad upgrade to do, even if there is a horsepower increase (which I'd doubt if the rotors are the same size/shape, and only a weight difference). Best to stick with CAI, Exhaust, etc to get a bit more kick out of the car. I think I'll be happy with the power, it's handling for me that I am concerned about and reading reviews lately it's something I don't think I'll have to be concerned about :) Sputnik 01-21-2003, 09:50 PM It's still a bunch of experimental stuff, and I'll let others 'speriment with it, thank you. ---jps Hercules 01-21-2003, 11:20 PM Originally posted by Sputnik It's still a bunch of experimental stuff, and I'll let others 'speriment with it, thank you. ---jps Ditto :) maxcooper 01-22-2003, 06:10 AM I think there may still be some confusion between "MMC brake rotors" and "MMC Wankel engine rotors". As far as I know, there has never been an MMC Wankel engine rotor. There are lots of MMC brake rotors, including some installed on cars with rotary engines. It sounds like the suggestion is to upgrade to MMC Wankel engine rotors. That would be expensive and time consuming, considering you would have to do all the development. It isn't really an option for the average owner. And at 8.5 pounds already, it is not clear that there would be much to gain over the stock rotors. Racing Beat makes aluminum side and intermediate housings for the 13B. I doubt if they have any with side exhaust ports, however. -Max Supercharger 01-23-2003, 06:21 PM This mod is intended for road racing and drag racing applications. It would be a good project for Mazda Motorsports. zoom44 01-23-2003, 07:13 PM Originally posted by Supercharger ...and drag racing applications. who's drag racing the rx-8:confused: |
