Anyone upgrade fog light bulbs
Old Feb 13, 2004 | 09:43 AM
2001F4S's Avatar
This has got to be fairly straight forward, but the manual says leave it to the dealer. Is accessing the foglight bulbs that much of a project?
Old Feb 13, 2004 | 12:02 PM
ELX13's Avatar
CHAH-LAY MURPHAAAAAY!
it's not as hard as the manual says 2001f4s, but it is a chore. u gotta get under the front of the car, remove something like a hundred bolts and have a pretty linber hand. (ok, a hundred bolts is a little exaggeration )
seriously, it takes some time but u can do it yourself. i did. :D
i ordered some hoen's. expensive but they look good and really do match the HIDs quite well.
Old Feb 13, 2004 | 02:18 PM
mikeb's Avatar
100% Italian
you need size h11
Old Feb 13, 2004 | 03:20 PM
2001F4S's Avatar
Thanks ELX13 and Mikeb. I will give it a shot. I bought H11 Nokya for the fogs and Hoen's for the high beams.
Thanks again
Old Feb 16, 2004 | 07:09 AM
Lacroft3's Avatar
If you live in a cold climate watch out for the Nokya H11 lights.I had them installed on mine and it cracked the lens on the fog lights themselves.The wattage is to high the dealer told me.The correct wattage is 55w the Nokya bulbs are 80w.
Old Feb 16, 2004 | 09:46 AM
Omicron's Avatar
I personally went with the AdvancedOptik 55W H11s in my fogs and the 65W H9s in my high beams. Both are a nearly exact match for the HIDs in color, and the high beams are considerably brighter than the factory bulbs... or so I'm told. I have yet to find the time to put them in! But many others have. Check out this thread for lots of discussion on changing out the bulbs.
They can be purchased here.
Hope this helps.
Old Feb 16, 2004 | 10:58 AM
2001F4S's Avatar
Thanks will hopefully get to them this weekend
Old Feb 16, 2004 | 08:54 PM
mlino01's Avatar
I wonder if PIA makes that size bulb.
Old Feb 17, 2004 | 12:53 AM
2001F4S's Avatar
I don't think PIAA makes either a H9 or H11. I bought the Nokya H9 bulbs for the fogs and the Hoen's for the high beams
Old Feb 17, 2004 | 10:12 AM
mxmedina's Avatar
My aftermarket fog light
Here is a set of aftermkt fog lights that I upgraded the light bulbs. They now have 100 watt bulbs instead of the 55watt bulb. The differeance is a brighter road:D
Old Feb 17, 2004 | 08:26 PM
1SIKRX8's Avatar
Hey ELX13, this is a dumb question, but which HOEN bulb did you go with? there site has four different kinds on there, the XenonMatch, titanium, all-weather, and the plus. thanks jeremy. oh yea for the fog lights.
Old Feb 18, 2004 | 01:09 AM
Omicron's Avatar
Re: My aftermarket fog light
Thought I heard that the last guy who pit in 100W bulbs kept popping fuses. Have you had that problem?
Old Feb 19, 2004 | 05:43 PM
tommy12g's Avatar
Pistons.. What are those?
I put the Nokya h11 and a month later I blew one, not the fuse the actual bulb blew up !! i still have debree from the bulb in the enclosure that i cant get out!! i now have the XD5 h11 and those are the exact same color as the Nokya and have had those for 3 months and no problems , im in South Fla so the cold is not the only place were bulbs blow
Old Feb 19, 2004 | 07:23 PM
ELX13's Avatar
XenonMatch if i remember correctly. i'll doublecheck when i get home and re-post.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Brokegang
Jan 3, 2016 12:45 PM
wayloco
Sep 1, 2015 09:03 PM
