Rotary Titus
02-12-2004, 10:14 PM
I'm going to buy a bottle of 5W-20 to keep in my trunk. I was wondering what brand mazda dealers use? Does it matter if I use the same brand that they put in at my service?
View Full Version : Oil brands mixing? Rotary Titus 02-12-2004, 10:14 PM I'm going to buy a bottle of 5W-20 to keep in my trunk. I was wondering what brand mazda dealers use? Does it matter if I use the same brand that they put in at my service? Nubo 02-13-2004, 02:19 AM I've read that it's best to stick to a single brand in case the different additive packages don't work well together. rx8cited 02-13-2004, 06:32 AM Originally posted by Rotary Titus I'm going to buy a bottle of 5W-20 to keep in my trunk. I was wondering what brand mazda dealers use? Does it matter if I use the same brand that they put in at my service? Hi Rotary Titus, Here's an opinion for you from CITGO (http://www.citgo.com/Products/LubesOils/MythsAboutEngineOils.jsp) "Myth: You can't mix brands of motor oil. Fact: Mixing brands is not the best practice because the additive systems in each may be different and when mixed may not function as efficiently as desired. However, no serious problems will occur if you must add a different brand of equivalent quality between oil changes. It is very important to maintain proper oil level. " I'm personally going to continue using my case of Castrol in between oil changes regardless of what brand oil the dealer uses during my oil changes. It gets too complicated logistically otherwise. Here's another reference (http://news.theolympian.com/specialsections/Auto/20020413/5578.shtml) that says basically the same thing. regards, rx8cited Rotary Titus 02-13-2004, 02:06 PM I see.... thanks! r0tor 02-13-2004, 05:51 PM All the oil companies are pretty much using the same kinds of additives anyway nowadays, just in different quantities. Its not going to hurt anything. Trx8 02-22-2004, 07:11 AM I checked with my dealer to see what they use when they change the oil (Motorcraft 5W-20 Blend). I now carry that type to top-off the oil. I am at ~1800 miles, am down 1/2 quart, and haven't added any yet. Rotary Titus 02-22-2004, 07:32 PM motorcraft eh?.... any recommendations on the "best" oil without going synthetic? RX82004 02-22-2004, 09:30 PM I know my dealer uses some form of Castrol 5w20...just put a bottle in...so do not all dealers use the same? rx8cited 02-23-2004, 05:56 AM Originally posted by Rotary Titus motorcraft eh?.... any recommendations on the "best" oil without going synthetic? My favorite flavor ice cream .... um motor oil is Castrol GTX 5W-20. :D. MyLadyDeb 02-25-2004, 11:54 AM so then my question is - because my old car mechanic asked me - are we NOT to use synthetic oil in the RX-8? Stick to the 5W-30? I'm at 2,200 and down about 1/2 quart - haven't added anything yet. Want to do it right from the get go. Thanks. |
