04 RX8 Idle????
Old Oct 17, 2010 | 08:02 PM
chonniedotcom's Avatar
04 RX8 Idle????
Hey gang....
Sorry in advance if this has been talked about already... I searched and was not able to come up with a solid answer.
I was wondering if there was anyting else you are supposed to change in Access Race Tuner program to adjust the Idle RPM...
I changed "ECT Based -A" and "ECT Based -B" up to 1000 at the warmest coolent temp available... but it does not appear to change anything with regards to Idle speed. I put it up this high to see if ot changed... I was looking to get it to Idle between 850 - 900 if possible.
Sometimes when AC clicks in and out.. it will sputter / get rough for a couple seconds... I think if the car were to Idle a little higher... it would be perfectly smooth through those transitions.
Most of the time the car idles great.
Any input would be great...
Thanks.
Old Oct 17, 2010 | 08:17 PM
Loki's Avatar
When was the last time the spark plugs were changed? Mine was getting rough in the same way, new plugs cured it.
Old Oct 18, 2010 | 09:45 AM
I dunno.....
I have had the car 4 months... got it from a Mazda Dealership who said they did the "once over" on it... but who knows really what that means.
May get a set of plugs... as it will need them eventually.
POP them out and see what they look like. :-)
Thanks for the advice.
Old Oct 18, 2010 | 10:21 AM
Good idea, you always want to assure you are starting fresh with a proper tune up. I would not trust that the dealer would have spent to do the plugs, coils, etc.
ironj221
36
Jan 20, 2026 08:28 PM
ladnarf1
Apr 29, 2021 11:53 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
netrovers
Jul 20, 2015 03:32 AM
Belalnabi
Jul 17, 2015 07:48 PM
