phrenetiK
09-16-2010, 01:30 PM
im gonna head out and do this as a first since i don't want to get embarrassed as a noob at a real SCCA until i have a little experience at least, plus the cost is only 30 dollars.
as posted on houston imports...
http://www.houston-imports.com/forums/showthread.php?t=587301
"September 26 Angleton Gymkhana. Round 6
at Angleton Raceway ( 27250 FM 2004 Angleton, TX 77515 )
Diver cost $30.
Spectators 13 yrs & up $10
Children 5- 12 yrs $5
Under 5 free
Driver sign-in and tech is from 8:30 - 9:30 a.m. Tech includes; Helmet (DOT Motorcycle), Seat belts, NO excessive fluid leaks, NO loose items in or on car, Battery MUST be tied down, No Corded tires.
NO ALCOHOL OR DRUGS ALLOWED ON SITE
Classes:F (stock FWD),MF (Modified FWD),R (stock RWD),MR (Modified RWD),A (stock AWD),MA (Modified AWD).
:Stock Class is allowd (air filter,cat-back ex.,brake pads,adjustable struts (not coilovers),lowering springs,200 tread wear tire)
:Modified Class is open mods
OK Morning session Tech and Reg. stops at 9:30 AM. 1st car on course at 10:00 AM. If you do not make it then you will have to wait for the afternoon session and fun runs. So when you get there get your car ready for tech ASAP, because if it is not been tech and ready to run by 9:30 then you have to wait. This means tires changes need to be done by 9:30.
Loaner helmets are available."
Diver cost $30.
Under 5 free
