r1concepts
08-05-2010, 04:17 PM
R1 Concepts Inc. is proud to offer Premium Rx8 rotors!
I am offering the Premium series rotors which are made with stronger iron cast metal (G3500) for overall tension strength. The Premium series rotors which is the top of the line series out of the two that I carry (E-lines & Premiums). The rotors are cast with a 50/50 center split for better heat distribution. Premium utilize a black Electro-coating finish applied on the hubs and inner vane structures providing long lasting corrosion protection. Original stock size, will bolt right up with no modifications needed.
Here at R1, we take many precautions in drilling rotors. We drill with smaller diameter holes and counter sink each hole. You can also go with just slotted only or whatever design you wish. When ordered with slots, every R1 rotor will come with our exclusive Diamond Slot design (45 degree angle end points), to help release trapped debris. Also a good indicator for rotor wear life.
http://www.r1concepts.com/act/PDSdrilledslotted4.jpghttp://www.r1concepts.com/act/PSslotted4.jpg
http://img188.imageshack.us/img188/136/hawkshps1.jpghttp://img341.imageshack.us/img341/5726/posiquietpads.jpg
http://img339.imageshack.us/img339/1517/stoptechlines.jpg
AVAILABLE STYLES
Slotted Only
Drilled and Slotted
Drilled Only
Dimple and Slotted
Custom
(ft/rr = front and rear)
04-08 Normal Suspension
FT/RR PREMIUM ROTORS: $265
04-09 Sport Suspension / Touring / Sport
FT/RR PREMIUM ROTORS: $275
PADS
FT/RR POSI CERAMIC PADS: $85
FT/RR STOPTECH PERFORMANCE PADS: $100
FT/RR HAWK HPS PADS: $140
BRAKELINES
FT/RR STOPTECH STAINLESS STEEL BRAKE LINES: $160
BRAKE FLUID
ATE SUPER BLUE (1LT): $13
CALIPER PAINT
G2 Caliper Paint: $33
(all colors of rainbow, black, silver, pink available)
SHIPPING: $30 (AK, HI AND INTERNATIONAL WILL COST MORE)
Contact Info
IF YOU HAVE ANY QUESTIONS OR WANT TO PLACE AN ORDER.
PM: r1concepts
Email: melvin@r1concepts.com
Phone: 888-712-6623 ext. 7011 (MON - FRI 9-6pm PACIFIC)
AVAILABLE STYLES
Slotted Only
Drilled and Slotted
Drilled Only
Dimple and Slotted
Custom
PADS
BRAKELINES
BRAKE FLUID
CALIPER PAINT
Contact Info
PM: r1concepts
