View Full Version : need a pipe nipple i can not find in the usa
bumblebeerx8
08-02-2010, 06:30 AM
Hello I am in need of on close pipe nipple. I am a pipe fitter and have checked with many suppliers and have come up empty. The thread specs are m20x1.5 threads and it will be a close nipple with no pipe showing anywhere just all threaded. Let me know what you can do I am willing to pay for your trouble, shipping, and the part. Let me know what you can do. Thanks Josh
paulmasoner
08-02-2010, 06:50 AM
this kind of thing isnt my forte, but i know folks out here who would be in the know(not rotary ppl). if i could make heads or tails of what you were asking for i can get word out...
bumblebeerx8
08-02-2010, 07:17 AM
Bacically it is a metric pipe close nipple with thread pitch of m20x1.5. A close nipple is a nipple that is all thread and no pipe showing in-between the thread ends. I can post a picture of one from work to help in a bit. This is for a oil relocation kit and the pipe nipple matches the oil filter threads.
bumblebeerx8
08-02-2010, 08:12 AM
Here is a picture the close nipple is on the left the shoulder nipple is on the right
http://i666.photobucket.com/albums/vv26/bumblebeerx8/1280754023.jpg
StuttgartRX8
08-02-2010, 09:41 AM
I ordered a relocation kit for my car and I think it came with one of these. I'm in Kiev at the moment so I can't check it out til the 9th.
bumblebeerx8
08-02-2010, 09:44 AM
Sounds good my kit came with one but I need a second. I called the place I got the kit from with no luck.
paulmasoner
08-02-2010, 11:41 AM
gotcha, was just the terminology i wasnt educated in :)
asking now
paulmasoner
08-02-2010, 01:56 PM
well, i have someone who can MAKE the piece for you if it comes to that. still awaiting better answers, maybe it will take a day or two since machine threads are not very common on pipe nipples.
FWIW you can get 1M lengths of solid rod properly threaded, but you'd still have to cut to size, and drill out your center
dannobre
08-02-2010, 02:01 PM
^Problem with that is it is threaded from both ends into the middle :)
paulmasoner
08-02-2010, 02:03 PM
eh damn good point dan
paulmasoner
08-02-2010, 02:11 PM
any chance you could pull one from a junkyard? i mean pull the OEM pipe nipple where the filter mounts from factory, and use it?
bumblebeerx8
08-02-2010, 03:11 PM
I believe the OEM attachment would also only be one sided.
paulmasoner
08-02-2010, 03:24 PM
i was wondering if it would be, or if it was 2-sided and threaded into the OE mounting base as well.
Your a pipe fitter iirc?... could you silver braze an OE nipple/barb etc in place? what ive been told it can be as strong as a single piece design...
i digress though, i'll keep an ear out, but as you may have noticed via my posts, the guys i am talking to are all the hardcore DIY types. the kind of folks that build/fab ANYthing they need nearly.
the overwhelming response i get is:
-fab it on a lathe
-junkyard it and depending on OE design use it as you intend, or silver braze what you need together
bumblebeerx8
08-02-2010, 04:08 PM
I do not have access to the equipment to braze at this time silver solder or brazing is good for fusing very uncommon material together at least that's when I have done it. Like stainless to brass. It really doesn't fuse it more fills a void n a socket connection. I have thought about options such as fusing stuff together but may call a machine shop. I have worked on many German design things and thought over seas could b a option. At least a much simpilar one
dannobre
08-02-2010, 04:13 PM
If you showed us the application a bit more there might be another way to do it :)
paulmasoner
08-02-2010, 04:23 PM
I agree with Dan, i have been working on the assumption that you are trying to mate the oil filter nipple/screw to the hose barb at the relocated end of a kit... dunno how true that is
bmblebee: ok, i was not sure, the silver brazing was just something i had seen. the euro guys i am talking to all seemed to think that machine threads on that type of piece is very uncommon as well.
bumblebeerx8
08-02-2010, 10:27 PM
yes i need the nipple to mate from the top of the RB oil samwich plate to the one side of the relocation kit the other nipple i need to use under the car to mate the other side to the oem filter. There is one think i have checked into with out much success is using a standard nipple (1/2") and using a different oil filter from another car. I can see issues with out know oil pressure specs and other variables. I have contacted mobil 1 which is the filter i use with very little help other that they can mate up but they do not have specs they can compare.
dznutzuk
03-03-2011, 01:28 AM
Do you still need this? If so please post another pic as the first one doesn't work. I can get you anything you want.
dannobre
03-03-2011, 03:43 PM
Why do you need the RB sandwich plate and the filter relocation plate? That is asking for a leak :)
Usually there is a port on the oil filter adapter for a pressure sensor..or you could add one elsewhere easier than the RB plate...what do you need to hook up there that you need both?
