Rx8 left sitting without Sparkplugs
Old Jul 27, 2010 | 01:45 PM
Faria's Avatar
LikeThunda
i removed the sparkplugs from my rx8 and the car has been sitting for about 1 month already....i was going to replace them, but the shipment never came in.....
i was wondering if this could have damaged the motor??? i will be getting the sparks in a few days so i will be able to test......i just want to know ahead of time if i could have damaged something by letting my car sit for so long without the spark plugs inside
Old Jul 27, 2010 | 01:59 PM
I would say, it could. It could rust, hornets could build a nest, etc.
Old Jul 27, 2010 | 02:05 PM
Faria's Avatar
LikeThunda
well the car is sitting in a semi underground garage. so its cold.
Old Jul 27, 2010 | 02:14 PM
Either way rust is an issue. Rust inside the motor is bad.
Old Jul 27, 2010 | 03:47 PM
Aseras's Avatar
there prob enough crap in there it wont matter. squirt some oil in and turn the engine over a few times. OR run own the the auto parts store and get some rx7 plugs for about $20 for all 4. they work just the same, it's all ive ever used on my 04 rx8 for over 100K miles.
Old Jul 27, 2010 | 03:53 PM
^ Don't use RX7 plugs. Use the required plugs. Most would not know the difference driving normally but running the wrong plugs could cause warranty issues if the dealer discovers you were using the wrong plugs. If there is anything in there then there is not much you can do about it now.
Old Jul 28, 2010 | 01:41 AM
yiksing's Avatar
the giant tastetickles
If rust is present in there, its not gonna be good
Old Jul 28, 2010 | 02:06 AM
laythor's Avatar
I zoom therefore I am.
you're fine, put in the plugs
Old Jul 28, 2010 | 06:48 AM
Huey52's Avatar
Registered Zoom Zoomer
Any flash rust will quickly burn off. You'll be fine.
Old Jul 28, 2010 | 10:32 AM
Faria's Avatar
LikeThunda
Good News,, My Car Started Right up!! =D redlined a few times, got on the free way to clean the engine up...
weird thing was, that as soon as it started... my check engine light was on..my DSC Light was On.. Radiator Light...
the car was on jackstands..... as soon as i dropped it..and restarted the car...it was Fine....
The only Issue im having right now is a vibration coming from my Shift **** that was not there before i had left it sitting for so Long...
Old Jul 28, 2010 | 10:39 AM
Good to hear. I hope you let her warm up completely before redlining. Just swap out all the fluids and drive her around a lot to get her juices flowing again.
Old Jul 28, 2010 | 11:29 AM
Faria's Avatar
LikeThunda
yeah, i let her warm up Everytime, i wont redline unless its been warmed up completly/drivin for a while..
Old Jul 28, 2010 | 11:39 AM
Huey52's Avatar
My shifter vibrates a little as well, amplified by the short shifter leverage. It's normal and probably prior unnoticed by you, as you're now more sensitive to everything that's going on post your 8's downtime.
'course it could also be time for a transmission fluid change.
Old Jul 28, 2010 | 11:42 AM
Faria's Avatar
LikeThunda
yeah, i havnt driven it in a while.soo it feels good to drive it again.... and i was thinking about changing the Transmission fluid...im not sure its been changed before..... ive been keeping up with my oil changes also.
Mazdakevin
Mar 10, 2016 12:32 PM
vapor2
Oct 8, 2015 02:08 PM
T_Mags
Jul 24, 2015 11:29 AM
RX7.9
Jul 20, 2015 12:01 PM
