speakers not working correctly
Old Jul 18, 2010 | 06:04 PM
UltrasonicKing's Avatar
my left door speaker goes in and out and the left speaker doesnt work at all, what could the issue be, the fuses or do i just need new speakers.
Old Jul 18, 2010 | 07:22 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Well.......it's not any fuse.
More than likely it's connections and/or your radio left channel is just shot.
Try banging a little bit down by your right knee on the side of it and see if either one pops back on for awhile.
Old Jul 18, 2010 | 07:26 PM
Speed_8's Avatar
i have a driver sides bose for sale if interested 350 its yours
Old Jul 20, 2010 | 11:10 AM
wowo76's Avatar
there's a post in the DIY section about a failed/failing relay in the amps that are mounted in the doors. I have the same issue and I am going to try that fix before replacing the units.
Old Jul 24, 2010 | 09:59 AM
I already do that and it still pops back out, but on the right side it doesnt do anything.
Old Jul 24, 2010 | 10:00 AM
Can you post back to let me know it that works.
Old Jul 28, 2010 | 08:25 AM
wowo76's Avatar
NJ
i just replaced the relay on the driver side bose amp in the door, and so far no cutouts. my passenger side is still cutting out, but i haven't replaced the relay yet.
I'm extremely confident that this is the correct measure of action for my issue.
if you do order the updated relay, order a spare incase you screw up fitting the pins as the replacement relay is a tad bigger than the oem one.
good luck
Old Jul 28, 2010 | 07:47 PM
You have a short in the speaker wire.
Old Jul 29, 2010 | 01:11 PM
wowo76's Avatar
That's what I thought before I replaced the relay on my driver side door speaker, and that was not the case since after replacing the door amp on the drivers side, I've not had a single cut out once.
The passenger side amp hasn't been "fixed" yet, so it is still cutting out. By this weekend, the passenger side should be fixed.
Here's the link to the repair https://www.rx8club.com/series-i-tech-garage-22/front-door-amp-repair-201080/
Last edited by wowo76; Jul 29, 2010 at 01:12 PM. Reason: Added link to fix for amp
Old Nov 26, 2013 | 06:39 PM
Thee Thomas'z's Avatar
speaker problems
I have a 04 rx8 and my front speakers have sound but seems as if the woofers arent working. i hit a bump and heard the extra lows then it went back off. is this the same problem???
Old Nov 27, 2013 | 08:39 PM
RotoryVirgin's Avatar
I was having this issue as well. I took the door panel off, cleaned the connections to the amp and speakers, added some dielectric grease. Problem solved.
Old Dec 26, 2013 | 08:08 AM
anoble1's Avatar
2004 RX8 Owner
I had the same issue on my car. Sometimes if I closed the door it would work for like 2 seconds till it stopped working at all. I did the fix. It worked like a champ. Worth it. Get you a good soldering iron
https://www.rx8club.com/series-i-do-...ay-fix-218790/
rotarywanker
Dec 8, 2022 05:56 PM
fullsmoke
Nov 24, 2015 04:09 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
CMRine04
Jul 27, 2015 09:46 PM
Majictoast
Jul 18, 2015 06:45 PM
