weid shifting problom
Old Jul 16, 2010 | 01:49 PM
alex zhuk's Avatar
So i threw in a syncro saver and today i realized that i can go into reverse with out pushing down on the shifter?!!!!
did i put the shifter in wrong?
Old Jul 16, 2010 | 01:54 PM
Jon316G's Avatar
Grasshopper
Did you remember to install that triangle metal piece that holds down the shifter?
That piece is what has the physical hard stop on it.
Remove the center console again and see how the tab on the shifter looks next to the hard stop (or take a pic so we can see it).
Old Jul 16, 2010 | 02:21 PM
alex zhuk's Avatar
well i put in the syncro saver....witch includes removing the triangle????
Old Jul 16, 2010 | 02:31 PM
Jon316G's Avatar
Grasshopper
I never installed one before, but I just saw a pic of it installed.
EDIT: Looks like that triangle piece is still there.
It looks like a small arch on the right side of the shifter.
Old Jul 16, 2010 | 02:52 PM
alex zhuk's Avatar
ohhh man im a roooockieee, i read the instructions wrong, im always just so about getting a new part in i don't read everything carefully!!!
thanks for the help problem is fixed
also those that have problems with there gears grinding i would really recommend the redline HEAVY shockproof gear oil.... unless you drive in the winter and temps are below 20f.
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
