BIG problem tuning with GREDDY EMANAGE
Old Jul 15, 2010 | 07:00 AM
RodrigoSoares's Avatar
EU BIG problem tuning with GREDDY EMANAGE
While I'm waiting for my first base FI map from Jeff (does not run idle), my mechanic wants to tune the 8 (everybody tells me he is the best in PORTUGAL to tune your car, at the dyno).
In order to do so, he will use the Emanage Ultimate from greddy that comes with the bolt-on turbo kit.
Problem: the greddy emanage needs a specific rpm signal adapter (Item # Greddy 15900909)
Problem: that item has been discontinued by Greddy.
Question: Where can I find one?
My mechanic also doubts of the AP maps. He says that since the 8 doesn't have a MAP SENSOR, how can it read boost to calibrate the engine?
PLEASE HELP ME!!!! I've had my 8 on the shop for almost 3 months since we've started to modify it.
Thanks to everyone here.
Old Jul 15, 2010 | 09:09 AM
Mawnee's Avatar
I divide by zero
Your mechanic is an idiot...... dont let him tune your car.
Old Jul 15, 2010 | 09:47 AM
TX
Either he really is an idiot or something is being lost in translation. The "maps" created by MM have nothing to do with a "Map Sensor" (which our cars do not have). The RX-8 uses a MAF sensor.
But honestly do not use his (your mechanic) services. Use the Cobb AP and MM's tune and that is it. Yes it would be great to have MM tune your car on the dyno live but unless you wanna give him a vacation in Portugal, I don't see that happening.
Old Jul 15, 2010 | 10:24 AM
loooooooooooooooooooooooooooooooooooooooool
That's not a bad idea! hehehehe I can offer him stay in my place in the Algarve! heheheh
Just tell me something: have you get your 8 tuned by MM? Live or by email? How much boost are you getting?
Old Jul 15, 2010 | 10:51 AM
I just purchased a Cobb AP but my car is not turbocharged. However, most of my previous cars were so I have spent much money on tuning and dyno time. The Cobb AP is the best tool available for boosted RX-8's. I have seen MM's tunes and how they work on the dyno. I am sure ^ and some of the other experienced turbo guys will chime in but read the threads that are already here in the major Power subforum and you will learn a ton.
Old Jul 15, 2010 | 10:36 PM
Another question: maybe this has already been answered, but here it goes: is the boost limited by the fuel injection (x fuel delivered by the injectors means x air flow) or can I manually increase boost with a boost controller? What implications can result from this?
I'm asking because the greddy turbo with the bnr upgrade can go to 25psi (it is what Bryan says) and I've seen that most of the people with the greddy turbo only show dyno graphics with 6, 9psi.
I don't know how to explain myself better...
Old Jul 16, 2010 | 01:09 AM
Kane's Avatar
Senior Member
Dude, not to be an ***, but you need to do more research on how MAF cars are tuned and how Turbo systems work.
The RX8 does not have a built in boost controller like the WRX and ms3,6 - since the 8 was not boosted from the factory.
The system will be based on how you design and build it. Read the Power Adders for Dummies thread, it is stickied here under Major Horsepower Upgrades, it may help make sense of things.
Old Jul 16, 2010 | 07:10 AM
Thanks Kane. I've read the all thing. But my doubt is still this:
More air, more fuel. ok. I got bigger injectors so i can have more air in the engine. but how is that air pushed to the engine? will the turbo deliver the air according to the fuel capability or do/can i make the turbo to deliver more air manually until the fuel delivery capability? using a boost controller, for example. crap for my insufficient english...
can call me an *** because i'm learning... :P
Old Jul 16, 2010 | 07:20 AM
Kane's Avatar
Senior Member
You are confusing tuning with physics.... the air the motor takes in is based on the physics of your set-up (turbo, boost, piping etc) - the amount of fuel is based on the tune (assuming your injectors and pump don't max out on you).
So you mechanically set up the air delivery and then tune for the fuel..... this is actually an iterative process if you are smart, little air -> little tuning, add some more air -> more tuning..... and so on.
And all of that doesn't include timing.... which is a part of tuning too.
Old Jul 16, 2010 | 08:04 AM
Got it! You adjust your fuel depending on how much air is being delivered. For example: if i set my turbo for 12psi, i have to tune the fuel delivery considering that amount of air. right? in vey simplified terms.
Old Jul 16, 2010 | 08:08 AM
RotaryMachineRx's Avatar
SPOOLN8
^ Where MM maps will do all this for you and all you need to do is follow his instructions. Use MM maps... pointless to use GReddy E-manage especially if you already have a Cobb and are waiting for MM's maps.
Old Jul 16, 2010 | 09:20 AM
MazdaManiac's Avatar
Ask your mechanic to do this while you are waiting on me:
1) Open the hood
2) Open the PCM case
3) Remove the e-Manage
4) Throw the e-Manage in the trash
5) Reconnect the harness
6) Be happy
Old Jul 16, 2010 | 09:25 AM
Mawnee's Avatar
I divide by zero
^ lol
Old Jul 16, 2010 | 09:45 AM
1) Open the hood
6) Be happy
looooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooool
You're the best, Jeff!!! :D
The guy is kind of skeptic relating long distance tuning. He says he can do better. that's why i'm insisting in getting the thing tune by him too. then, i can compare both tune ups.
By the way, i forgot to say that i've a Greddy BOV RS type.
Thanks again for sharing your knowledge.
Old Jul 16, 2010 | 12:53 PM
If he doesn't understand how the AccessPORT and its tuning works, I would be very careful about having him tune the car at all, let alone with the ticking-timebomb that is the e-Manage.
Old Jul 16, 2010 | 01:45 PM
ok. i'll take your word. no tuning with the e-manage.
i'll be waiting anxiously for your map
Thanks again.
Old Jul 16, 2010 | 01:51 PM
Rodrigo: I have had Jeff tune my car in person and via email and I can say the results speak for themselves. While my car is not turbo'd, I have seen significant results with Jeff's tuning and what he has done for other turbo'd owners.
I think Jeff and I have put over 75+ RX-8's on the dyno together and he's tuned a great deal of them.
You will not find a better tuner for the RX-8 with the AccessPORT then Jeff.
I know your mechanic is skeptic of the AP because he's never used it and most of these tuners are used to traditional piggy back systems like the e-manage but the AccessPORT is a far superior tuning device and I'm sure he'll lighten up to it once he sees what it's capable of.
Old Jul 16, 2010 | 01:59 PM
mysql101's Avatar
I can vouch for mazdamaniac. Turbocharged and all.
Old Jul 20, 2010 | 02:30 PM
arghx7's Avatar
AP vs EMU thing aside...
I have discussed some of the problems with the default Emanage Ultimate maps. Someone else has already explained the pinout and the wiring and potential issues there. Search.
xAgyex
Jun 3, 2026 03:47 PM
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
ktec
Jun 26, 2021 10:18 AM
Mxttz0r
Jul 5, 2019 03:19 AM
RicerX1
Jan 11, 2016 05:59 PM
