2nd gear grind
Old Jul 14, 2010 | 11:14 PM
hayden123456789's Avatar
TX 2nd gear grind
i own a 04 rx8 when i get the rpms over 5xxx and shift into second out of first it grinds horribly then to get it in i have to hold the clutch from 2 to 3 seconds what could it be?
Old Jul 15, 2010 | 01:51 AM
delta31tr's Avatar
Do you have the same issue when you downshift from 3 to 2? I had a similar problem with my 5th gear(without the clutch issue). You might have damaged the synchrons of the 2nd gear. Might need to change them.
Old Jul 15, 2010 | 05:19 AM
bse50's Avatar
#50
Known issue. Welcome to the new transmission club!
Anyway you may want to investigate what helped its wear. How many miles are on the odo?
Old Jul 15, 2010 | 10:56 AM
how much is it to fix the syncrons? and for be50 92,500
Old Jul 15, 2010 | 11:29 AM
paimon.soror's Avatar
I actually have this issue on my new S2 on a cold start. The remedy for me is to double clutch 1 - 2 and 2 - 3 until the engine and tranny is fully warmed up. Im not sure if this is at all related to your issue though.
Old Jul 15, 2010 | 12:45 PM
Hachi's Avatar
走り屋
This happened to me not to long ago. Almost the same exact symptoms except it was grinding at 4k, the dealer said that it was a pain to get to the syncros and it would take them a while to get it done. I left my 8 them while I was in Japan and came back surprised by a new transmission. Apparently it is easier to just replace the tranny than pull out everything to get to the syncros. Makes sense and I'm def happy with the result haha.
Anyways the dreaded 2nd gear grind is def a pain, even more so if your out of warranty.
Good luck everybody
Old Jul 15, 2010 | 03:24 PM
bse50's Avatar
#50
The synchros replacement is pretty expensive labor wise, they often have to replace more than the ones involved since there are other fragile "spots" and the shift forks bend pretty easily.
How's your clutch pedal?
Some s2 units came out with problematic transmissions, I can't remember the gears involved but a search should clear that up!
Old Jul 15, 2010 | 04:33 PM
my clutch pedal has not changed just it grinds still going into second and since i do need this car to be a drift car thats going to suck to have to replace the tranny
Old Jul 16, 2010 | 01:12 AM
delta31tr's Avatar
well at least now you know what to do
1. change of synchron
2. change the whole transmission
Its weird that rx8 tanny do cause some many issues to be honest. exp S2. weirddddd.
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
